Ray's SSM GE8 Base/Sport Progress
Old Apr 13, 2011 | 12:18 AM
  #61
ThEvil0nE's Avatar
LOL you hard parked so hard they popped out of play
Old Apr 13, 2011 | 12:40 AM
  #62
Hootie's Avatar
Originally Posted by Ray731
Well had a little mishap the other day...
I went to look at the 2011 Fit for 0.9 APR and to check if I'm on the recall list and apparently overextended the rear suspension along the way there. I have always wondered if this could happen with just lowering springs but I have never had this happen on any other lowered car. Yes I was hauling ass and yes I went over an unexpected large bump but I didn't notice it till I walked away from the car. Jacked it up and put the spring back in place. Man I need coil-overs!
-Ray
Dayum! I didn't know that was possible to even do. Good thing you caught that before leaving the lot.
Old Apr 13, 2011 | 12:47 AM
  #63
Ray731's Avatar
I know! I was like man how did my car get so low?!? OH SH!T! I'm glad it was the RH side cause the exhaust kept it from falling out!
-Ray
Old Apr 13, 2011 | 04:20 AM
  #64
Goobers's Avatar
yup, Texas Coyote mentioned it with his GD. He has Swift Springs, but used airbags for shocks. When he jacked up his car, the springs just fell out because the airbags allowed the suspension to move further than the stock shocks did.
I have Swift spring on stock shocks... I went over over a set of train tracks on a raised mound that practically sent me airborne (a little too fast)... springs are still there. I jacked up my car the other week to rotate the tires (while installing wheel locks)... lifted the back end completely off the ground, springs felt snug.
The Swift Springs I have, have a "dual coil" set up (I think they're a newer revision). If you look at pics of it... like this one from another member https://www.fitfreak.net/forums/fit-...tml#post931384 you'll see it. The tightly packed coils are for this very reason... if the shocks extend far enough to pass the main coils, the secondary will unwind to keep the springs seated. And the only way you're supposed to be able to pass BOTH, is during installation/removal...
Old Apr 14, 2011 | 12:11 AM
  #65
Ray731's Avatar
Yeah Drop Zone springs are a cheap alternative for those on a budget. I haven't heard anything like this as of yet. I will definitely be doing coil-overs next year. This makes me want to do it prior to the Mugen kit. I hope They'll stay in that long! All I need is a couple good months at work... Come on $$$!
-Ray
Old Apr 14, 2011 | 04:53 AM
  #66
Goobers's Avatar
I hate compromise. And I think I'll leave it at that.
I had more typed up, but I think it sounded more like ranting. So, I erased it.
Old Apr 14, 2011 | 07:15 PM
  #67
drumsauce's Avatar
Scary Ray! Glad you and the Fit came out ok! =)
Old Apr 17, 2011 | 02:19 AM
  #68
Ray731's Avatar
Hey thanks! I think I just came out with a real life experience... Another reason to go coil-overs soon. There were no comments on this so I went with a lower priced solution. I wanted to change as few parts as possible until I was out of warranty and still customize the look.
Now I have to drive more careful... or carry a jack with me...
-Ray
Old Apr 17, 2011 | 03:26 AM
  #69
Goobers's Avatar
Yeah, it took a while for me to realize why Swift changed their design to the "dual coil" springs. And it seems pretty much for this very reason.
Did you check to make sure the spring and the shocks are alright? I mean, when the spring fell over, there was basically nothing hold that corner of the car up, besides the shock and the spring on its side. The shock could've bottomed out... or if the spring (on its side) was big enough, taken quite a bit of weight on the coils. I don't know how these springs might react to being crushed on the wrong axis... can't imagine it would be good.
Old Apr 17, 2011 | 11:20 PM
  #70
Ray731's Avatar
The spring was loose between the solid axle and the exhaust. The strut was on the bump stop. I think it happened when I pulled in the driveway. I could explain but it sounds worse than it was. Long story short, the dealer is off the freeway and I turned in fast and slowed down really fast. That combination while going up the driveway caused the spring to have just enough time and room to come out. So I drove less than 1/8 of a mile on the bump stop. I know I would have noticed it if it had happened sooner and the other side would have come out too instead of just one side.
This looks like a good reason for any spring manufacturer to change the design of their springs. I just don't see Drop Zone doing this.
The spring was never compressed on the side and the strut seems ok for now. We'll see if there is any leakage when I do the coil overs.
Old Oct 4, 2011 | 10:11 AM
  #71
Ray731's Avatar
Time flies...
Well it's been 6 months and I haven't been able to do anything... Busy job and paying for vacation has done me in. Finally I am able to do more to my Fit! I have ordered APEXi N1 ExV coilovers, HKS Hipower exhaust, and bought bnib Mugen sides here from another "Fit Freak" member. All of these items should be in by Friday and on the car this weekend! I will post my progress as I get the parts and install them.
-Ray
BTW going to attempt the HD diy lip
Old Oct 4, 2011 | 11:20 AM
  #72
fitisbamf's Avatar
-Ray
i was goin to say gd shocks have shorter stroke so it cant fall out i ordered a set of tokikos for a gd and i have "cut" (they were for a gd so the seat was like 1/2 inch too small, easy fix) megan springs so im low!
Old Oct 4, 2011 | 12:39 PM
  #73
FitStir's Avatar
Thumbs up
Nice progress thread; I like what your doing.
Old Oct 6, 2011 | 08:52 PM
  #74
Ray731's Avatar
Moar stuff
Ok Ok Ok... I got some stuff from Fedex today! HKS Hipower Exhaust and Mugen sides. I immediately put the HKS on and saved the Mugen sides for tomorrow.
Here are some pics!
-Ray
Loosen the two bolts on the exhaust flange.
Remove and reinstall the Rubber mounts.
Nice and easy install... Not as loud as I thought it'd be but definitely nice not Rice!
Old Oct 6, 2011 | 08:57 PM
  #75
Hootie's Avatar
Exhaust looks good Ray! Can't wait to see the Mugen sides on. What are you up to next Thursday? Red meat & race fuel should be going on at MSR Houston from 3 PM to 6 PM.
Old Oct 11, 2011 | 12:17 AM
  #76
Ray731's Avatar
Update!
This has been a very busy but productive weekend!
I got the Mugen Sides on just in time for the WTF Monthly meet! Good to see Vanct out there! Saturday I received my coilovers. I started installation LATE Sunday... Finished today after work.
Mugen Sides
The drivers side was test fitted prior to my purchase. I spent a LOT of time cleaning the old double stick off and then put new 3M double stick on. I followed along with College Hills Honda's Mugen Side install DIY video.
Episode #160 - 2nd Generation Honda Fit MUGEN Side Spoilers - YouTube
APEXi ExV
I started with the rears because of ease of install
Rear
Out with the old
In with the new
Front
Out with the old
In with the new
You must use everything from the original upper mount or you may break something.
Before
After
Old Oct 11, 2011 | 12:40 AM
  #77
Hootie's Avatar
^^ I'd rock it.
How is the ride with coil overs now?
Old Oct 11, 2011 | 12:41 AM
  #78
Ray731's Avatar
^^ I'd rock it.
Actually much better than the DZ springs!
Old Oct 20, 2011 | 07:52 PM
  #79
Ray731's Avatar
Wheels
Well finally got off my ass and put the wheels on the car! Here are some pics... All the way down and drove to work no probs... I don't like the gap in the front but what can you do...
-Ray
Last night:
Today:
Old Oct 20, 2011 | 09:42 PM
  #80
1SickVeilsideZ's Avatar
Looking good man, nice progress on the car, just went through the whole thread. Where did you get the spoiler from if you don't mind me asking?
