Jazz Headlight help
Old Jan 28, 2011 | 09:13 PM
ernmasterz's Avatar
Jazz Headlight help
Hi guys. I'm actually quite new here and need help with my Honda Jazz. (My Jazz is '06 but I am sure the same facts can arise for any model)
The other day someone stuck some sort of paper tape onto my headlights. After I removed it, the sticky residue remained and sort of ate into the covering of the headlights. I've had it professionally cleaned and even they could not remove it. Recently I was told by my mechanic that my can would not be able to pass a safety check due to the residue stain on my headlights. I've contacted the local Honda dealership who told me that the only way to fix the problem is to replace both headlights.
Seeing as each headlight costs AU$450 (around US$480) I find it a bit shocking that the only way to fix this problem is by paying such a large amount of money.
Therefore I am just wondering whether what the dealership said was the only way to fix this problem, keeping in mind that only the outer covering (the glass protecting the bulbs inside) is damaged.
Thanks in advance for all the help I can get.
Old Jan 28, 2011 | 09:38 PM
ThEvil0nE's Avatar
a blow torch might fix that
Old Jan 28, 2011 | 09:44 PM
ThEvil0nE's Avatar
Old Jan 29, 2011 | 10:58 AM
pauljazz's Avatar
Try furniture polish. Just the normal household polish.
Old Jan 30, 2011 | 07:47 AM
specboy's Avatar
is the residue something that ate away at the plastic? or is it an extremely strong adhesive that isn't coming off? Many people use GooGone to clean up residue (I've never used it on clear plastic however). if it has eaten into the plastic itself, polishing like mentioned above would be your only option other than replacing the lights. Junk yards might be your first step, then Ebay... besides that, the dealer is likely your only other option.
~SB
chapsmcollon
Jan 2, 2019 12:13 PM
ernmasterz
Jan 29, 2011 08:38 PM
ernmasterz
Jan 29, 2011 01:22 AM
Andrew Green
May 26, 2009 12:58 PM
FELIXY69
Jan 7, 2008 03:42 PM
