Seat issue
Old Feb 15, 2011 | 08:16 AM
Blueskulker's Avatar
Seat issue
I have a 2010 Sport. It's about everything I expected with the exception of an issue that I have not yet been able to address with the dealer (warranty issue I hope). I have noticed that when cornering the drivers seat, and the passenger seat as well I think, makes a clunking or notching sound. It is not the back and forth adjuster rails, nor is it reclining. It seems to be the seat back clicking side to side.
I know that it is not the sound of a partially empty fuel tank from below the seats.
Anyone else run into this issue?
Old Feb 15, 2011 | 08:33 AM
xSimply's Avatar
Does it make the noise under hard cornering or pretty much any turn you make? I was going to say check that the bolts on the rails are tight but you said it's not rails. I know my seat was making making a clicking noise when I first got it but it was more sporadic and it went away when I made sure everything was tight and then set both chairs to different positions.
Old Feb 15, 2011 | 08:42 AM
Krimson_Cardnal's Avatar
^^DITTO^^
Most likely the front bolts on the seat rail. Pop the covers and snug them down - careful not to over do it. Issue has been discussed a few times before. Search seat rails might turn something up.
Old Feb 15, 2011 | 02:24 PM
2Legit2Fit's Avatar
Yeah the guy in charge of bolting down the seats on the GE8's was caught huffing paint in the women's bathroom at Honda. He has been moved to the floor mat installation department.
Old Feb 15, 2011 | 02:55 PM
Santiad's Avatar
i notice the same feeling as well but i thought it was due to my size and usage of the car....I've put some wrinkles in those seat cushions.
Old Feb 15, 2011 | 07:43 PM
AT the last (first) oil change I had the dealer take a look at the rail bolts. Not to say they did. But the problem seems to be in the seat back itself, rather than the base. When I corner right, it clicks, then is quiet until I corner left, then click.
Old Feb 15, 2011 | 07:45 PM
Occam's Avatar
I'm a hair over 180 lbs and put some wrinkles in the seat fabric. It's because the fabric is cheap.
Ditto on tightening the bolts. Had the same issue.
Old Feb 15, 2011 | 09:54 PM
deluxrockz's Avatar
Dude I have the same issue. I have heard that sound plenty of time on my car.
Old Feb 15, 2011 | 10:28 PM
malraux's Avatar
I'm betting on the seat bolts. There was a recent TSB on this, so your dealer might not have noticed it when you took it in before.
Old Feb 16, 2011 | 12:11 AM
flip's Avatar
Mine started as a click in the front seats, then got to where I even noticed a slight noise when shutting doors or going over certain bumps, tightened the bolts and it went away. I think we're all trying to encourage you to check out the bolts lol. wouldn't hurt or cost anything but a couple minutes to check.
Old Feb 18, 2011 | 05:54 PM
Santiad's Avatar
Using a socket wrench? Am at work and haven't had the chance to look at the bolts.
Old Feb 18, 2011 | 06:16 PM
Yep, going to be a 10MM bolt I'm thinking. The plastic covers snap off, pry the rear flanges apart and lift off.
Old Feb 18, 2011 | 06:22 PM
Santiad's Avatar
I'll check it out. Thanks!
Old Feb 18, 2011 | 06:40 PM
Occam's Avatar
You could use a herring, but a socket wrench works just a bit better.
14mm socket for the stock bolts.
Old Feb 18, 2011 | 08:33 PM
Red 05's Avatar
I'm nearly 50 pounds heavier than you, and I've been driving for almost 2 years and I have no wrinkles. Maybe I got lucky...
Old Feb 18, 2011 | 09:07 PM
Occam's Avatar
I think how you sit is a lot of it. Before I changed the incline of the seat, the limited rear travel and flat angle of the bottom meant that my knees were up and my thighs barely touched the front edge. As a result, all my weight was on the center-rear of the cushion.
Old Feb 21, 2011 | 04:09 PM
Santiad's Avatar
To the OP: I also had clicking and today I pulled off the covers and tightened the seats. The front right (by the center console) was way loose. Drove it afterwards, bouncing my fat ass all over to test it and NO MORE CLICKING. Def give this a shot. Enough pple have told u to already
aelk799
Dec 8, 2020 02:12 PM
fitbuddha
Apr 19, 2015 04:32 PM
phinegan
Aug 29, 2010 11:18 AM
vze29tgr
Jul 16, 2010 02:53 PM
Baxter
Jan 3, 2010 11:17 AM
