Rear passenger seat clunking noise
Old Jul 22, 2017 | 03:04 PM
aelk799's Avatar
Anyone experience a clunking noise from the rear passenger seat? Seems to only happen when someone is seated there. When i try to reproduce it, it sounds like it's coming from the part of the seat attached to the metal u-latch at the top. The u-latch itself is not loose.
It's a minor issue but super annoying!
Old Jul 22, 2017 | 04:52 PM
wasserball's Avatar
The seatbelt that is latched to the roof? Or, something under the hatch floor board where the spare tire is located? Or, the seatbelt buckle got tangled under the seat?
Old Jul 22, 2017 | 05:41 PM
aelk799's Avatar
it's definitely coming from the latch which locks the seat in place. seems the seat wiggles just a tiny bit while locked in place.
Old Jul 24, 2017 | 03:05 PM
skatana's Avatar
I have that same problem. Still haven't figured out how to fix it. I would wrap it with a piece of tape, but I'm worries it'll release while someone is seated on there.
Old Dec 8, 2020 | 02:12 PM
MrPeeps's Avatar
I'm having the same issue, just wondering if anyone has found a solution.
I tightened down the bolts holding the bracket (at the base of the seat) an 1/8th of a turn, but no effect.
The rod that runs through the bracket might be the cause as it moves a little while I rock the seat side to side.
Anyone else fix this?!?!?
jy1129
Sep 9, 2016 11:07 PM
shawnshank
Jul 27, 2015 01:23 PM
fitbuddha
Apr 19, 2015 04:32 PM
Blueskulker
Feb 21, 2011 04:09 PM
FrogDaddy
Nov 28, 2007 02:46 PM
