Hard shifting auto
Old May 25, 2013 | 06:42 AM
Jamieson's Avatar
Did my first ATF drain and fill yesterday with DW-1. Real easy. The plastic splash guard was nowhere near where the ATF was draining. Weird that the shop manual would recommend removing it.
It did seem to help. Upshifts seem a bit smoother and faster.
After 15 years driving my M/T Civic I'm still trying to get used to the A/T in the Fit. When rolling to a stop I sometimes notice a lurch when the transmission downshifts from 2-1 or maybe 3-1. Is this normal?
Also, if I come to a complete stop and then accelerate upshifts are fine. But if I do a slow "rolling stop" then accelerate the next shift is rather abrupt. Is this normal?
EDIT: yup, these shifting issues seem normal, lots of threads on this. I'll adjust my driving style, try S mode, manual downshifts with the paddles, etc.
Old May 25, 2013 | 07:08 AM
CasualFitOwner's Avatar
My wife's Fit auto doesn't seem to lurch when coming to a rolling stop.
Just curious, did you do the 3 quart drain/replace via the ATF drain plug only or do full 6 quart using the transmission coolant line?
I noticed - which could be my personal bias only - that when I went from ZF-1 to DW-1, doing 3 quart ATF drain/replace only didn't feel as smoother than doing the full 6 quart.
Old May 25, 2013 | 08:36 AM
Jamieson's Avatar
I did the simple 2.5 qt drain and fill with DW-1. At some later point I'll do another drain and fill.
Old May 25, 2013 | 11:32 AM
13fit's Avatar
Your rear lower mount may be going bad.
Im actually in middle of filling mine up so I can reduce/remove wheel hop.
You will need a 17mm and a 19mm socket to remove it to check.
The crossmember bolt will NOT come out unless you reach up and turn the head so a tab facing the rear of the car is aligned, well, to the rear of the car! Then youn can pop it out.
Do this i=on a level surface. The motor will want to fall FORWARD. No chance of you crushing your hand while doing this, and no need to support motor
mmm def
May 12, 2025 10:24 PM
m_x
72
Nov 16, 2018 04:10 PM
phuccer
Jan 30, 2011 07:19 PM
stuffandstuff
Apr 12, 2010 12:09 PM
scanner
Nov 24, 2006 01:04 PM
