Dead Battery Anyone?
Old Mar 12, 2011 | 05:45 PM
HondaFit4Fit's Avatar
Gurus, how long can I leave the Fit in storage without driving or starting up the engine before the battery will die? Will manually locking the car and disengaging the alarm extend this period? Thanks in advance.
Old Mar 12, 2011 | 06:04 PM
malraux's Avatar
It's better to disconnect the battery. Also check page 281 in the manual.
Old Mar 13, 2011 | 11:54 AM
jondotcom's Avatar
How long do you plan to store it? I would suggest you get a trickle charger if you are talking multiple months and you want to keep it connected. They are very common and relatively cheap.
Old Mar 14, 2011 | 02:27 AM
hammong's Avatar
If you're going away for an extended period of time, e.g. military depoyment or such, you have a few things to consider:
a) Fuel stability - you should add some Sta-Bil to the fuel and keep a full tank. This will prevent the gas from going bad. Follow the instructions on the Sta-Bil bottle for dosage. Be sure to run the car with the Sta-Bil long enough to treat the entire fuel system, not just the tank.
b) Store the vehicle on jack stands/blocks. Parking a car in one spot for an extended period of time may cause flat spots or sidewall bulging on the tires.
c) Definitely install a battery tender/trickle-charger. If you don't have access to a plug where you park your car, remove the battery entirely and keep it indoors with the trickle-charger attached. Then, when you get back, unhook it - take it outside, install it, and drive off.
Greg
Old Mar 15, 2011 | 05:39 PM
JOKER0808's Avatar
I left mine in storage for a year...Result was a trip to the dealer for a 105$ battery ;(
Old Mar 15, 2011 | 07:03 PM
raytseng's Avatar
trickle charger is the way to go. Be sure to get a more modern smart one, like batteryminder or batterytender.
Don't forget an extension cord if an outlet isn't nearby.
Old Mar 15, 2011 | 08:41 PM
TGIJoseph's Avatar
did you know oem honda battery's have a 3 year unlimited mile warranty?
Old Mar 16, 2011 | 04:51 PM
JOKER0808's Avatar
Yea I didn't have to pay...Just saying use a trickle charger and don't be a fool like I was....Meow
Jensen Healy
Dec 6, 2019 02:54 PM
GTRPLYR
Mar 12, 2015 11:19 AM
pzriddle
Jan 23, 2015 06:31 PM
slioch
Oct 23, 2011 08:39 PM
HondaFit4Fit
Jan 6, 2011 01:36 AM
