2nd gen Honda Fit don't have front dome light?
Old Apr 13, 2011 | 03:28 AM
fit.lunatic.mania's Avatar
Does anybody know if Honda Fit 2nd generation have front dome light? if they do, where can I buy one?
Old Apr 13, 2011 | 04:45 AM
Goobers's Avatar
Front dome lights? Well, I think the "front dome" lights are listed as "map lights." Right between the flip down visors, are a pair of lights (for left and right). Comes with the Sport trim (and Sport w/Navi).
Honda Fit Parts - Bernardi Honda Parts and Accessories <- you have to select Fit (already), then 2009/2010/2011 (these three are second gen), 5 doors (only option =.=' )... lastly, this is important... either sport or sportn (sayama vs suzuka isn't that important).
then on the next drop down list, select "electrical/exhaust/heater/fuel" (that's one big option). in the list, go to "interior light."
If you pick Sport... you get the part list for standard dual map light.
If you pick SportN... you get the part list for the module with two map lights AND a microphone (voice control for the navi).
Because it's a parts list... you can kinda pick and choose. Or just jot down the part numbers and order them for another online honda parts seller or even a dealership (I did that for some push pins).
Yet another option... go to a junkyard or used parts shop and look for it from a used 2nd Gen Sport or SportN Fit.
Old Apr 13, 2011 | 05:14 AM
dela's Avatar
click the link in my sig
Old Apr 13, 2011 | 07:46 AM
Goobers's Avatar
Which is not visible if you're using the mobile version of this site (no sigs are visible).
;d
Old Apr 13, 2011 | 10:18 PM
Thanks that was very helpful
Old Apr 14, 2011 | 04:42 AM
Black3sr's Avatar
Here is the list from an old thread
34253-671-003 - Light bulb (order 2 of these)
34405-SDA-305 - Right plastic lens
34406-SDA-305 - Left plastic lens
34404-SNA-A01ZD - Map light base
90148-S6A-013 - Ground/Mounting bolt (order 2 of these)
Here is link of install
https://www.fitfreak.net/forums/2nd-...t-base-ge.html
Old Apr 14, 2011 | 12:26 PM
Not quite sure about the wire part but i assume you connect to the dome light in the back to map light right?
Old Apr 14, 2011 | 02:58 PM
Black3sr's Avatar
Yes that is correct
Old Apr 14, 2011 | 03:04 PM
Is there specific wire do i need use? Specific thickness of wire do i need?
Old Apr 14, 2011 | 03:33 PM
j's_fit's Avatar
if you don't want to spend alot of money, you can also go and buy those LED strips and install them in the glove box, it also works very well as a dome light
this is what I did to my GE8
don't want to spend the money in buying OEM dome light (map light) so I went out and got those LED strips
like Can $20 for 3 strips
with the 3 strips you can cut them into 2 pieces ie) you now have 6 strips
My bro helped me install it!! oh....you might want to goto Honda and buy a OEM fog light switch (to turn LED on/off) so that it look nicer
in total the money I spend less than Can $30 and I still have 1 strip left!!
so let say if you want to read anything I just open the top glove box and there is light!!!
here are some pix of the finish product
3 strips in the front!
2 strips in the back (b/c truck's light is not very bright)
Old Apr 14, 2011 | 03:37 PM
Woo~ thats tight~ thanks for the info, but where do you got the light strips?
Old Apr 14, 2011 | 04:36 PM
Black3sr's Avatar
Did you read the link? He listed everything including the wire size.
Ebay or WalMart for leds
Old Apr 14, 2011 | 07:02 PM
j's_fit's Avatar
I picked up mine at a local auto parts place.......
u can easily pick up at ebay or from the web!!
or try Cool Gadgets at the Right Price - Worldwide Free Shipping - DealExtreme pretty cheap!!
jl0r
109
Jan 6, 2019 07:52 AM
kitkit201
Nov 26, 2012 11:32 AM
White_GE8
Jul 14, 2011 08:03 PM
Roger's Fit
Oct 31, 2009 02:23 AM
qbmurderer13
Jan 30, 2009 12:54 AM
