home made front lip
Old Apr 22, 2011 | 02:36 PM
GE8FTW's Avatar
home made front lip
i got the garage door liner and put it on yesterday
[IMG][/IMG]
Old Apr 22, 2011 | 02:54 PM
neil patrick harris's Avatar
that looks really good on the base. subtle and clean.
Old Apr 23, 2011 | 10:24 AM
GE8FTW's Avatar
All that I need now is the oem Honda fogs
Old Apr 23, 2011 | 06:45 PM
chunkylover's Avatar
very nice, where did you get the materials
Old Apr 23, 2011 | 07:05 PM
Klasse Act's Avatar
Lightbulb
I think I'm going to look into this myself but upon seeing your pic I need something else first....a set of springs Oh and btw, wrap those gelcoat mirrors with some CF vinyl too!
How did you install this, a nice write up could net you some rep
Old Apr 23, 2011 | 07:09 PM
GE8FTW's Avatar
I went to lowes got a bunch of self tapping screws the bottom lining of the garage door the rubber thing and made a bunch of holes and put them in very easy to do
Old Apr 23, 2011 | 09:35 PM
Texas Coyote's Avatar
I was in Lowe's today myself.. Their hardware prices are really climbing.. I have thought of doing the same thing as you have done and might get around to it sometime... I have wondered if it would be possible to use some small fender washers with the self tapping screws or would they create a wavy appearance? What you have done works well on a base model in both function and in creating a lower appearance.
Old Apr 23, 2011 | 09:49 PM
GE8FTW's Avatar
You have to use the self tapping screws and allot of them ore elase it will be really wavy there is no easy way around it and double sided tape wont work don't waste your money :]
Old Apr 24, 2011 | 12:10 AM
EvoFit's Avatar
there's already an existing DIY for this. i'm sure its the exact same for the base as it is for the sport.
https://www.fitfreak.net/forums/2nd-...front-lip.html
Old Apr 24, 2011 | 03:43 AM
Goobers's Avatar
How about flat steel/aluminum "bars"? Say 1" or just 1/2" wide, 1/4 or 1/8" thick and of varying lengths.
Basically, instead of having a bunch of screws... you use two screws to hold a piece of metal that then holds the part of the "lip" to the car. 4, 5 or 6 pieces should be able to get you around the curve of the bumper. If you want, you can do the same on the inside of the bumper to make it REALLY secure and change the screws to little nuts and bolts.
Hum, what's the point of this lip anyway? Just looks? I think it'd be kinda goofy though... at higher speeds, if a person in a neighboring car were to look at your lip, they'd see it flapping around a bit. It's "hard rubber," but it will still move to wind at higher speeds.
Old Apr 24, 2011 | 04:58 AM
1/2 inch aluminum angle and pop rivets and small fender washers on the inside... The angle used on the bottom would add rigidity to cut down on flapping and cutting V shaped notches on the part that is drilled would make it bendable to follow the contour of the lip...
Old Apr 26, 2011 | 01:52 PM
geomarathoner's Avatar
.....interesting....a garage door bottom seal......but does the hood pop open when your neighbor pushes the button on his garage door opener???
geo
Old Apr 26, 2011 | 02:25 PM
GE8FTW's Avatar
geo
Haahaha very funny!!!!
Old Apr 29, 2011 | 07:51 PM
Neebs's Avatar
Reminds me of my SiR lip on my old Honda Civic.
Nice job.
g95pteg
19
Sep 26, 2020 11:58 PM
sandblasted
131
Aug 3, 2018 12:12 AM
jasonh
Sep 14, 2011 11:02 PM
Fat Ping Cat
Jan 10, 2010 06:04 PM
coto
15
Apr 15, 2008 07:21 PM
