sirius radio
Old Jun 14, 2011 | 05:40 PM
Norman99's Avatar
sirius radio
i know that the factory installed radio on the 2011 fit sport is not designed to handle a sirius hookup. I want to get sirius but cannot decide which setup will go well. You know not glued to the dash. Blends with the dash. Any recommendations.
Old Jun 16, 2011 | 03:38 AM
SimpleFit's Avatar
What's your budget?
-SimpleFit
* I'm currently shopping aftermarket headunits with available Sirius/XM and Bluetooth. The Alpine CDE-123 and CDA-117 are near the top of my wishlist.
Not cheap, but great sound/reliability/features.
Old Jun 20, 2011 | 03:02 AM
Kimomono's Avatar
If you're looking for an iPod deck, Alpine makes some of the best ones. I had their old iDA-X001, and it was the best head unit I've ever had. That doesn't just apply to iPod units either. Alpine makes some of the best head units out there period.
Old Jun 21, 2011 | 12:30 AM
nkedge's Avatar
If you go with an Alpine deck, I have a KCA-SC100 (open box, unused) and an SCVDOC1 (new in box) that I'm looking to sell. As I understand it, if you want to use timeshifting features with Sirius + an Alpine headunit, you need to plug a portable radio into the SCVDOC1 which goes into the KCA-SC100 which then goes to the headunit. The SCC1 Universal Tuner does not support timeshifting, but if that's not a requirement for you, it's certainly a cheaper option. The KCA-SC100 is required in either setup unless you get one of the newer HUs that support the SXV100.
I'll sell the KCA-SC100 and SCVDOC1 as a pair for $70 shipped to the lower 48. Both items are unused -- I was going to install them but ultimately decided to forgo Sirius in the new Fit. Since I've canceled Sirius for now, I also have a Sportster 4 and Sportster 5 (both used) that I'd be willing to sell to anyone that's interested.
If nothing else, I hope some of this helps. I spent a lot of time researching the options to get Sirius integrated with an aftermarket HU and hope that at least someone can get some use out of the info!
Old Jun 23, 2011 | 09:44 PM
Krizz's Avatar
Not positive, but supposedly The Sirius half of SiriusXm has quit making new radios. Eventually, there's going to be a SiriusXm ver 2.0. At that point, new Xm radios will be able to use either service, whichever you sign up for.
There are still Sirius radio's available, SIRIUS Radio, SIRIUS antennas, SIRIUS accessories | TSS-Radio is a good place to look, and they are usually helpful. I've bought antennas through them a couple times, never had any problems.
Another option, if you have a smart phone, preferably with an unlimited data plan, just sign up for Sirius internet only, and just plug a line into the phone's headphone jack and the stereo's aux port, and get Siri off your phone.
Fair warning, I get much fewer drops from my old Sirius One unit with the antenna just tossed up on the dash, than I do when using the phone, droid 3G.
Old Jun 24, 2011 | 09:28 AM
Norman99's Avatar
Installed the sirius radio and works great, Stuck it in the forward cup holder. Only problem is that the wire that plugs into the aux radio port is insightly. Is there an adapter that mounts to the connector in the upper glove box that would receive the plug on the wire from the radio? Doesn't make much sense but I am not a radio person.
Old Jun 24, 2011 | 09:51 AM
neteng101's Avatar
Use a retractable mini DIN cord for a neater look. Or you can snake the wire behind the head unit and dremel out a small hole close to the aux port, but I figured the retractable cord was a lot easier and wouldn't show if you removed the radio down the road when selling the car.
The upper glove box has a USB connection, so it would require the proper electronics to be used as an audio input.
Old Jun 24, 2011 | 10:21 AM
Norman99's Avatar
Where can I find a retractable cord? Walmart?
Old Jun 24, 2011 | 11:32 AM
neteng101's Avatar
Walmart might have them, or could try Staples...
Scosche® rePLAY - Retractable Audio Cable for iPod & MP3 | Staples®
That's what you're looking for. Its still exposed/visible, but there's no slack so it doesn't look all messy.
sooznd's Avatar
Norman & anyone else with satellite radio-would you post a photo of your setup? I am thinking of getting XM radio.
I am already using the front left cupholder next to the console for my gps --don't want it to be too cluttered
Old Jun 24, 2011 | 12:07 PM
neteng101's Avatar
This is the topic I posted back when I did my XM install (has pics)...
https://www.fitfreak.net/forums/2nd-...tml#post493943
Old Jun 24, 2011 | 12:12 PM
Norman99's Avatar
Mine is sitting in the cup holder. I didnt want it on the dash or the air vent. it does not look all that good but I will paly with it. The only thing I dont like is the wire from the aux on the radio to the sirius. Cheaper that a radio replacement/
Old Jun 24, 2011 | 01:47 PM
sooznd's Avatar
I like where you put the XM radio--looks almost like it came stock on the car.
Kirk.el
Mar 4, 2020 04:04 PM
Kirk.el
May 11, 2018 11:47 AM
Ursenay
Aug 29, 2012 06:56 AM
spudbiker
Jun 12, 2009 02:31 PM
abernat
Dec 30, 2007 12:45 PM
