It's the little things build.
Old Sep 8, 2023 | 12:17 AM
  #61
myblackhatch's Avatar
Junk Yard Finds and more 5 lug prep
When I went to the junkyard I found a newer than mine ge8. Poor thing. The seats were trash and it was smashed up front so I grabbed a bunch of goodies off it. All 4 door panels, all the door window plastics and other little things not worth mentioning.
New door panels. Mine were pink from the sun.
Here I am working on the torsion bar from the CRZ. Bushings get removed for some polys and there was so spots that need the metal worked a bit. Shes now ready for sand blasting and powder coating.
crz torsion bar
Old Sep 18, 2023 | 08:02 AM
  #62
k24 prep
Transmission still needs to be cleaned but eventually the case will get powder coated. I realized I don't actually have everything I need and now have two separate orders with Honda for nuts, bolts and misc stuff. Nothing exciting.
Old Sep 18, 2023 | 08:11 AM
  #63
304 Stainless flange. I have a box of 304 stainless joints and 5 foot tube sections coming in to start setting up the header design.
Old Sep 18, 2023 | 09:15 AM
  #64
Pyts's Avatar
It's looking really good!
​​​​​​I wanted to ask about your stainless exhaust flange there. It's bolting up to cast aluminum, yeah?
Is that kind of set up commonplace?
Old Sep 18, 2023 | 10:09 AM
  #65
There will be a metal gasket between them but otherwise yes that is normal for performance based applications.
Old Sep 18, 2023 | 08:50 PM
  #66
mykizism's Avatar
very nice k motor in a Fit is going to be fast
Old Sep 19, 2023 | 12:11 AM
  #67
Lets keep our fingers crossed. There is still alot of work to get done.
Old Oct 13, 2023 | 10:12 AM
  #68
updated the main post
CR-Z Brakes - Rotors are incorrect and don't fit
Old Oct 13, 2023 | 11:14 AM
  #69
mykizism's Avatar
What do you mean are incorrect.. is the offset wrong or whats going on.
Old Oct 13, 2023 | 11:44 AM
  #70
The rotors sit too far back and hit the caliper bracket.
The setup is fit knuckle, fit bearing, cr-z spindle, cr-z calipers, cr-z pads and cr-z rotors.
The cr-z has a wide stance and it gets that from the knuckle. I ordered the spindles new from Honda and never had the cr-z knuckles to compare.
Now I am on the hunt for a rotor that will fit.
You can see how it sits on the bracket in this picture.
Old Oct 13, 2023 | 03:38 PM
  #71
mykizism's Avatar
That's good to know.. looks like you are running CRZ lower control arms too.
Old Oct 13, 2023 | 03:40 PM
  #72
mykizism's Avatar
I have a CRZ knuckle... but never had a chance to compare it to a FIT knuckle.. they look like they are the same however, I'm sure they have slight differences. When I get a chance I will try to compare them to the FIT knuckle.
Old Oct 14, 2023 | 10:59 AM
  #73
On a side note. I took the cr-v brakes off my EK9 and the caliper brackets have the same bolt pattern as the fit/cr-z. I bolted everything on and it actually fit better than the cr-z rotor/caliper but still wont work as it also hits. This would most likely work on a cr-z which would be a bigger brake upgrade.
My issue here is I wanted to keep the factory fit suspension geometry in the front by keeping the fit knuckle but if I cannot find a rotor that works I will be forced to switch over to the cr-z knuckle.
Old Oct 19, 2023 | 12:39 AM
  #74
Updated again.
Wheel closer
Rear Bar Bushings and some fresh paint
Old Oct 19, 2023 | 04:01 PM
  #75
mykizism's Avatar
Nice updates.. been thinking about your brake situation.. is there any particular reason you are using CRZ brake setup in lieu of an another setup?
Old Oct 19, 2023 | 09:42 PM
  #76
Nope, Cr-Z stuff is bigger than OEM fit and I had them already. ohh and 5 lug rotor. Just using what I got. I ended up using a 3m spacer that i milled down to fit behind the rotor. It spaced it out enough that it wont be a problem.
Old Oct 21, 2023 | 12:26 PM
  #77
CRZ- Torsion Bar Install
This damn bar put up a lot of fight.
When you do everything by yourself you have to improvise sometimes.
I had to use the front brace to pull the torsion bar into place to get that second bolt in.
Old Oct 21, 2023 | 07:37 PM
  #78
First post on page one has been updated with more images.
Old Oct 22, 2023 | 10:22 AM
  #79
Updated the main post with more images again
Rear disk just looks so good compared to drums
Old Oct 23, 2023 | 07:38 PM
  #80
mykizism's Avatar
Looking good.. starting to become a real car.. images don't do it justice.
