Issue with Recirculating lever
Old Aug 8, 2011 | 10:26 AM
Kingfisher's Avatar
Just noticed this am that my "recirculating lever" would not move from fresh air to recirc, when the car was moving. Once I arrived at destination, it moved freely. Any suggestions??
Old Aug 8, 2011 | 02:22 PM
monkeydave's Avatar
did you have it on the windscreen vents?
Old Aug 8, 2011 | 05:34 PM
huh, werd. maybe it was just stuck? did you recently have a stereo installed? if so, (im not 100% sure on the GE's) but on the GD i had to undo 3 cables going to the hvac including that lever you speak of to remove/install the deck.
Old Aug 8, 2011 | 06:24 PM
mahout's Avatar
Apparently for some reason your deflector door is penned by the incoming air. I can see it at high speed but not usual speeds. You might check the linkages to make sure its not bent.
Old Aug 8, 2011 | 07:00 PM
FITMugen's Avatar
It happened to me only in the winter. Water gets into cable and freeze up the cable. The ice melt after I drive for awhile. The I can move the level freely.
Old Aug 8, 2011 | 07:52 PM
Krimson_Cardnal's Avatar
There really isn't any conection to that cable and the car moving. There is a possibility the cable isn't adjusted correctly. By dropping the glove box you can see the cable end and the air box control. Moving the control will ID it.
lesterlai12
Aug 17, 2022 06:41 PM
Fit2009BaseAT
Nov 2, 2014 11:42 AM
75r90rider
Sep 26, 2014 06:22 PM
spathfinder34089
Dec 1, 2010 12:33 PM
alvarospatchez
Aug 18, 2010 12:25 PM
