Advice on eyelid vinyl
Old Aug 30, 2011 | 07:32 PM
FittedOnEm's Avatar
Alright, so I have a little issue with the set of eyelids I got from TFBDesigns. For some reason, you can see through the vinyl making the chrome housing visible through the eyelid. It appears it's more "ghosted" than an actual solid eyelid. It takes a lot away from it, so I was wondering what you guys think I should do. You can see through them in pretty much all light conditions except if the light is directly over the eyelid.
These pictures aren't edited in any way/shape/form, and I tried to include a few different lighting scenarios. Pictures were taken with a Canon 30D w/ an 18-55mm lens at about 3:30 PM (mid day).
Far Away:
You can clearly see through the eyelid here.
Notice the outline of the housing in both of the eyelids.
Direct Light:
You can't see any of the housing depending on the angle you stand at (in this case, with direct light on the eyelid).
Different Lighting Angle:
You can faintly see the housing in the passenger side.
Housing visible right about the turn signal.
Close Ups: Three different lighting scenarios.
Passenger Side:
Driver Side:
Shade:
The pictures honestly do them justice. They usually look like this (taken with a Motorola Droid at about 7:30 AM).
Right now, the options I can think of are:
1) Remove them
2) Leave it the way it is
3) Pay for a second set and double up the vinyl, *hoping* that the issue goes away
4) Getting two entirely new sets, with flat black on the bottom to block out all the light, then a layer of SSM to give it color.
5) Screw it all and get base headlights
My intent is not to put down TFBDesign in any way, they've been great with all of my questions and everything. I just need input on what to do before I make a final decision.
ANY input is appreciated!
Old Aug 30, 2011 | 08:34 PM
Bthasht's Avatar
I vote remove them and keep them off.
Old Aug 30, 2011 | 09:11 PM
Santiad's Avatar
remove them....the line they provide doesnt look right for the shape of the headlight
Old Aug 31, 2011 | 01:25 AM
loquitocrxsi's Avatar
in white are less both I am planning to get them off for stetic reasons Name:  IMAG0332.jpg
Old Aug 31, 2011 | 03:43 AM
Black3sr's Avatar
They look like overspray. Ditch them.
Old Aug 31, 2011 | 04:11 AM
Texas Coyote's Avatar
Wild Bill, why don't you go back to bed man... An old guy like you needs all of the beauty sleep he can get... I'd be asleep except this is the 3rd day in a row without A/C and it is almost 90 degrees in here without it... Yeah it's taking a toll on my good looks.
Old Aug 31, 2011 | 04:50 AM
Black3sr's Avatar
Who needs A/C? I just turned ours off.
Old Aug 31, 2011 | 10:00 AM
FittedOnEm's Avatar
I'm gonna leave them on for the rest of today to see if they grow on me... if not I already have the stuff for my next headlight project on order
Old Aug 31, 2011 | 12:05 PM
FitSSM2k10's Avatar
I think they look good :P I'd keep em.
Old Aug 31, 2011 | 03:13 PM
SenBlue09's Avatar
these must be removed. and than black out the headlight housing instead
Old Aug 31, 2011 | 04:16 PM
Vanct's Avatar
^what he said.
It looks ok, but not great due to the transparency. Even if you get another pair to overlay on top, it will still be like 10% transparent.
Car looks good btw.
Old Aug 31, 2011 | 07:46 PM
FittedOnEm's Avatar
i just pulled them off haha
i have a temporary (possibly permanent) idea on what to do with the headlights, so i'll update on that once i get everything
Old Sep 1, 2011 | 11:43 AM
Fit4Spl's Avatar
I like mine, but then again I made them myself. I no longer have a vinyl plotter but I have the file and a friend who owns a vinyl business if I ever decide to remove them and then redo them.
Old Sep 1, 2011 | 03:06 PM
im not a fan of eyelids so take them off.
but if you must have them i think the semi-transparent looks ok (for wat it is).
Old Sep 1, 2011 | 07:17 PM
FittedOnEm's Avatar
I already pulled them off. The issue wasn't the design of the eyelid, it was the transparency that really bothered me.
mike410
Sep 21, 2022 10:39 AM
AtticusFit
39
Aug 2, 2020 04:18 PM
JoeLrgr
Mar 28, 2012 10:45 PM
mhmmmatthew
Nov 21, 2011 01:18 AM
pwnstar
Oct 3, 2008 09:37 PM
