Ok Steve244: How DO you get 40+ mpg on your Fit?
Old Sep 12, 2011 | 10:28 PM
specboy's Avatar
Originally Posted by mahout
60 psi, downhill on an untraveled interstate, with a tailwind. you might want to read those 40+ mpg stories with a grain or even a pound of salt.
Originally Posted by neteng101
Has your Fit been fixed for the MPG software issue? Without that, a 2009 Fit is easily 4 mpg over actual mileage calculated at the pump, that meter is pretty much useless info.
As I'm sure a few of you have seen (but I'll repost for the newb's to the forum). My lifetime Economy is just under 38mpg, I have a 2009 and have had the economy update to the ECU. I also calculate using an Android App called MyCars (formerly used GasUpLogger for Windows Mobile).
I'm not heavy on the gas pedal by any means but I'm also not driving like a Granny. I'm almost down to the wear bars (3/32) after about 26K miles of driving and I do enjoy the "twisties".
For those that wish to see, I have two years of history logged at the link below.
https://www.fitfreak.net/forums/2nd-...les-38mpg.html
Also, of note, I filled up today and drove home (about 6 miles from the gas station on relatively level ground and I pulled in the driveway with the economy meter saying 47.1mpg. I won't be able to sustain that for the week but i have had 43 & 44mpg weeks but the weather has to be right for that too. Reset the trip meter at the top of a long hill and coast down... you'll see your economy in the 60's. LOL.
~SB
Old Sep 12, 2011 | 10:54 PM
GVlog's Avatar
Given that mine's a 2012 (mpg software should be fine) and that I've been able to hit 39 mpg on a route that included Hwy 1, SR 156, Hwy 101, and Hwy 680, I think there's a good chance I could do 40 mpg on Hwy 5 as long as I'm not getting tailgated or succumb to the temptation to floor it. I might have a chance at it during the Thanksgiving holidays.
In any case, averaging 32-35 combined (in my town and routines) on a daily basis is great.
bunz559, don't fret about your mileage. I took my daughter to a concert in San Francisco and had to do a lot of driving around the city. My mpg averaged the worst ever with all the stop-go-turn. I think it was 27.
Old Sep 12, 2011 | 10:59 PM
JeffChap's Avatar
Yes, it has, as I stated in my earlier post. With the update, my indicated mileage decreased about 4 mpg.
Old Sep 13, 2011 | 07:18 PM
debudebu's Avatar
Originally Posted by Steve244
Sounds like you're driving normally in the city. Shifts between 2.8K-3.5K are normal (the shift logic in the auto does this under low-moderate acceleration). Shifting at lower RPM lugs the engine. While it might save some gas, it isn't kind to the car.
The EPA estimates are realistic, some will do better some will do worse.
If you drive constant speeds between 45-55mph high 30's or maybe even 40mpg isn't unrealistic; but this isn't a "normal" driving pattern for the majority, I think.
shifts between 2k and 2.5k do not lug the engine unless you accelerate really hard or are going up hill.
Old Sep 13, 2011 | 09:26 PM
wetphoto's Avatar
At 70-75 on the freeway, no a/c on, I get between 40 and 42. With A/C it drops to about 38. Better mpg without cruise. A/T, 36 psi in tires. Other than that, nothing special. Get 32-33 mpg in town with a/C
luciusad2004
May 14, 2014 12:32 AM
Grinder12000
Sep 26, 2012 06:12 PM
'12Fit
Jul 10, 2012 04:05 AM
NMG
Aug 20, 2007 06:42 PM
Doc Holliday
Aug 1, 2007 11:59 AM
