How do I change the alarm settings?
Old Sep 21, 2011 | 07:13 PM
mauraobenshain's Avatar
Question How do I change the alarm settings?
I have a 2011 Fit Sport. The problem I have is that when I park at work (in a gated parking garage right next to my building), larger, noisier cars set off my alarm. It's really annoying. How can I change the settings of the alarm so that if I lock it from the driver's side button it doesn't alarm, but still maintain the alarm if locked with the key??
I'm worried that someone is going to get more annoyed with the alarm than me and key my car... or worse.
Help!
Old Sep 21, 2011 | 08:20 PM
bunz559's Avatar
is it the stock security unit? i had no idea that we could adjust the sensitivity level...
Old Sep 21, 2011 | 09:04 PM
malraux's Avatar
Given the normal security system doesn't have a shock sensor.... You should check the instructions for your aftermarket one.
Old Sep 21, 2011 | 11:58 PM
rprpclark's Avatar
Does anyone pay attention to car alarms, other than to think its accidental.
Old Sep 22, 2011 | 05:26 PM
as far as I know, it's stock. I didn't add anything to my car, I've only had it since February...
anyway, I don't want to change the sensitivity; I just want to change how it alarms - set by the key is good. I want to be able to lock my car from the driver's side lock and it NOT alarm itself. Does anyone know if this is possible?
Old Sep 22, 2011 | 06:03 PM
Goobers's Avatar
Are you sure you didn't get a "KARR" alarm from the dealer!
Old Sep 22, 2011 | 06:11 PM
I don't know - how would I find out?
Old Sep 22, 2011 | 06:31 PM
Goobers's Avatar
Most obvious would be a sticker on your windows indicating it.
Another place to check would be your purchase receipt for the car. Would be listed there, if you have it.
Old Sep 22, 2011 | 06:43 PM
For the sake of getting my question answered, pretend I have one. How the hell do I keep it from going off every time a noisy or heavy vehicle drives by?
Old Sep 22, 2011 | 06:45 PM
Better yet, if I do indeed have a KARR alarm, how the hell do I remove it?
Old Sep 22, 2011 | 07:40 PM
flip's Avatar
You need to find the "brain" of the alarm, usually a little black box with little wires going into it. They tend to hide them somewhere under the drivers side dash. If its not there look under the passenger side. Once you find it you may see a little inset knob for a small screw driver to fit in, with this knob you can change the sensitivity. If you want to completely remove it it could be a little more difficult if it is tied in with the factory keyless. If not its just a matter of unplugging the wires from the "brain". If it is tied in then certain features may not work once removed.
Old Sep 22, 2011 | 11:51 PM
TrungLam's Avatar
If you can't figure out if you have an aftermarket alarm or not, please don't touch anything else. Take it to a knowledgeable person and have it properly disconnected/removed/adjusted... Whatever floats your boat.
Old Sep 23, 2011 | 01:09 AM
Issue resolved guys: found a KARR owners manual off of the prius forums. That's right, not only are their cars pretentious hybrids but their forum respondees are far more helpful.
Old Sep 23, 2011 | 01:53 AM
flip's Avatar
Did you read my response? I believe it sufficed at least a little...afterall it is a "little black box with a knob for a small screwdriver with wires coming out of it". Sorry it didn't help though.
Old Sep 23, 2011 | 02:18 AM
yes, after I found the prius forum. Your response was by far the most helpful; at least I know what I'll be looking for tomorrow. My last post was more directed toward the comment of "don't mess with anything, have someone else look at it." That just pisses me off. It's my damn car, if I want to tinker with it, I will do as I damn well please. Just sayin'.
Old Sep 23, 2011 | 10:58 AM
Krimson_Cardnal's Avatar
Can't argue with sound advice - you're sounding like a pretentious prius owner.... perhaps you came to the wrong forum.
Old Sep 23, 2011 | 11:20 AM
that was really more of a joke, but, whatever...
thanks, everyone. I've got it under control.
ssforcey
Aug 30, 2015 05:15 PM
FitfulKenny
May 5, 2015 12:11 PM
vansandam
Aug 5, 2013 01:45 AM
teebar47
Sep 21, 2009 11:57 AM
bobmorning
Apr 12, 2009 08:33 PM
