Android on the Fit?
Old Nov 9, 2011 | 08:08 PM
Red 05's Avatar
Android on the Fit?
So I'm not an Apple guy, went with the little green guy. While I like my phone, I can't get my Fit to read my music files off of my SD card. Even if I tell my phone to go to USB storage, the Fit just says unsupported. I'm wondering if anyone else has gotten Android to work on the Fit.
I might try partitioning off a bit on the SD card, but I'm a little busy with work...
Thanks in advance!
Old Nov 9, 2011 | 08:36 PM
IRO-Bot's Avatar
Hmm, my music works off of my android phone when I plug it in. Your files are just MP3s? Only plugged it in couple times though. Haven't really fiddled with it. Right now I have my USB Flash drive in it with AAC files and it works fine.
Old Nov 9, 2011 | 09:44 PM
Red 05's Avatar
All of my music is MP3's, and it sits in a folder on my root. I've tried two different Androids (Optimus V and Triumph) and Android 2.2 and 2.3.5. I'm confused....
Old Nov 9, 2011 | 11:17 PM
neteng101's Avatar
Get a Tunelink and just wireless stream your music, hook up the Tunelink to your aux port. Get a Proclip mount/holder for your phone, it can be your music player/Pandora/GPS/etc in-car.
Tunelink Android: The universal wireless Bluetooth to FM and direct connect in-car audio solution for Android based mobile phones and devices
Device Holders and Dashboard Vehicle Mounts - ProClip Car Mounts for Mobile Phones, GPS, and Handheld Devices
Old Nov 10, 2011 | 01:35 AM
IRO-Bot's Avatar
That's funny, because I have a Optimus V too and it works fine. I have my files in a folder in the root too and I can switch around through the folders inside that folder. All I do is plug it in and then hit use as USB Storage then hit AUX on the screen and it opens one of the folders.
Old Nov 10, 2011 | 01:37 AM
Jamy's Avatar
And this is why non-technical people don't like androids.
Old Nov 10, 2011 | 02:29 AM
Goobers's Avatar
Thanks in advance!
it's possible the phone is NOT making the SD card accessible in USB Mass storage mode... but only the internal memory.
another thing is, have you restarted your phone? I know that once in a while the Fit will pop up with that error when using my ipod touch, even in the middle of playing a song. the only solution is to force reboot of the ipod and restart the car (or switching into and out of the diagnostics mode). Simply powering off and on of the radio via the power button isn't enough. That power button is really more of a standby mode, than actual power.
Old Nov 10, 2011 | 03:40 AM
buckyfit's Avatar
My iPod shuffle doesn't work on the Fit either.
Old Nov 10, 2011 | 08:40 AM
Schoat333's Avatar
It has always worked fine with my android phones. I use a thumb drive now tho, because its much easier, and I can just leave it in.
Droid CM7
Incredible CM7
Fascinate CM7
Droid Charge 2.3.6
Thunderbolt CM7
Old Nov 10, 2011 | 06:27 PM
Red 05's Avatar
Ill see if i can move music to internal storage on my triumph, because it has some actual memory. I even tried moving from 2.2 to CM7.1 on my triumph, to no avail.
Oh, and I'm plenty tech savvy enough, its just I can't for the life of me get the damn thing to work.
Anonymoose
Apr 10, 2016 06:57 PM
tron
Oct 13, 2014 07:51 AM
cmchan
Jun 5, 2014 09:54 PM
Desmond Lamar MacRae
Apr 28, 2014 04:15 AM
SkEEzY_GT
Mar 20, 2011 10:09 PM
