Lifter/Fuel Injector Noise!?!
Old Dec 25, 2011 | 01:30 PM
schwimmair's Avatar
Merry Christmas!
I bought a 09' Fit a few days ago and noticed a "ticking" noise while driving. The "ticking" noise follows the throttle so I am assuming it is a engine related.
From the research I have done it sounds like this is a normal issue and Fit engines make "ticking" noises due to the lifters and the fuel injectors.
I know in cold weather this is common and the noise goes away once the oil warms. With my car however it seems to make the noise from on to off.
I checked the oil level and it looked good.
So... is this normal?
Thanks so much for your insightful answers.
Schwimm
Old Dec 25, 2011 | 01:52 PM
Steve244's Avatar
The valve train in Fits does seem noisier than other OHC 4cyl cars I've had. This may be due to the plastic valve cover and closeness to the cabin.
Valve adjustment is not recommended less than 100K miles "unless needed." It's not trivial as it involves removal of the intake air chamber and removal of the shroud at the bottom of the windshield. Might cost a few hundred dollars at Honda. (while the power train warranty is 5 years 60K miles, it doesn't cover adjustments).
If nothing else, you might have the Honda svc dept check it out and give their impression. Also you might have some warranty from Carmax that may cover this if they need adjustment.
Old Dec 27, 2011 | 05:16 PM
schwimmair's Avatar
Thanks Steve!
Old May 14, 2012 | 11:02 PM
jeon's Avatar
Originally Posted by schwimmair
Merry Christmas!
Schwimm
I know im late with this but the thing i've done was that i swap the other injectors to the other side and the problem got fixed. on the other hand, im not that sure if the ticking comes from the injectors since valves might also be other consideration.
danielmorrison
Sep 26, 2016 09:13 PM
Mister Coffee
Nov 27, 2014 10:29 AM
swiftmove
Jul 7, 2013 02:17 AM
fujisawa
Aug 7, 2012 05:52 PM
Pith
Mar 20, 2011 12:30 PM
