Cargo Cover Installation Question
Old Feb 27, 2012 | 09:39 PM
FAZER's Avatar
My car has been broken into twice, so I finally bought the cargo cover and tried to install it today.
Finding the holes for the snaps was easy using the push pin method, but I am having the hardest time trying to install the clips on the tailgate for the strings.
Am I doing something wrong? It seems like no one else is having this problem, but I just cant get the clips to go on, its like the clip is way too tight, I tried to open up the clips a little with some pliers but still no go. Anyone have any advice?
Old Feb 27, 2012 | 11:04 PM
malraux's Avatar
Old Feb 28, 2012 | 01:17 AM
GTRPLYR's Avatar
I improvised using a key to open the clip a bit and then they slid right on. So maybe you just need to open it just a little more? I know those clips a grab pretty darn tight.
Be careful I read in another thread someone scratching the glass trying to get the clips on.
Old Feb 28, 2012 | 02:51 AM
kgb4187's Avatar
From what I remember theres little indentations on the tailgate, gotta slide the clips on at an angle.
Old Mar 3, 2012 | 11:46 PM
lowered_klass's Avatar
Mine were super tight as well.
I was nervous about forcing anything as well, but don't worry. Give them a good push, and they'll go on
I would avoid opening the clips up too much (to make install easier), only because these clips 'pull up' the cover when you open your hatch. If they're too loose, you don't want them popping off.
Just had a thought... I guess you could try smearing a little lube where the clip has to go, like WD40 or something similar? Might help?
Old Mar 4, 2012 | 01:20 AM
Fit2Live's Avatar
One went right on but the other one was a much tighter fit. Ended up using the key trick to open it up just a little bit then put it in at an angle and it went right on. Been using it for about a month now and it hasn't come off at all.
Old Mar 4, 2012 | 05:32 PM
Nicotine's Avatar
where did you order the cover from? i'd like to have one as I havn't tinted my windows yet!
Old Mar 5, 2012 | 08:02 PM
GTRPLYR's Avatar
Got mine at Honda Parts World which is based in Seattle. Had one of the cheapest prices I found on the cargo cover and the shipping was slightly better for me being based on the west coast.
Old Mar 6, 2012 | 01:12 AM
Vash's Avatar
i ended up just reclining the back seats all the way back instead of installing the pushpins.
2012FitFan
Dec 22, 2013 09:04 PM
littleblackcar
Oct 25, 2013 11:30 AM
DigitalDude65
Jul 28, 2013 08:04 AM
cspan37421
Aug 24, 2012 11:17 PM
turanuk
May 28, 2010 12:47 AM
