What are some "plug and play" horns? Besides the Accord ones.
Old Sep 8, 2012 | 12:03 AM
Swangger's Avatar
First thread!
I bought a 13' Base Model Fit couple of weeks ago and was thinking about swapping the horn. I have absolutely no experience with ANY wiring, relays, all those good stuff. I am willing to learn though so if there is someone who is willing to teach me like I am five, I will be greatly appreciated.
So back on topic, what are some alternative plug and play horns for my Fit? Pics & Links preferred
Old Sep 8, 2012 | 12:11 AM
SieGunso's Avatar
there's another thread about horns going on just a little lower, why not check there for info
Old Sep 8, 2012 | 03:40 AM
Swangger's Avatar
I did, but I have no knowledge on how to put together a relay and stuff so I can only install plug and play horns. I'm a car noob
Old Sep 8, 2012 | 04:13 PM
MeTaLoFeArTh's Avatar
Check the other thread for my reply. No one is going to teach you like you are 5, but there is a ton of info on the internet if you are willing to put in the time and effort to teach yourself.
My installation was my first time working with a relay or with wire connectors, but I did a LOT of homework before I attempted it.
If you are not comfortable doing it on your own, there's no shame in paying a shop to do it. It's much cheaper than electrical problems down the road.
Old Sep 8, 2012 | 08:13 PM
SieGunso's Avatar
there was a link on the 2nd page to that thread of someone putting 1 together
https://www.fitfreak.net/forums/fit-...s-install.html
Old Sep 10, 2012 | 10:33 AM
FitStir's Avatar
The Accord horn is an easy swap, but some have complained about the db level being a little low.
If I'm not mistaken the Ridgeline horn also works.
Old Sep 11, 2012 | 04:48 PM
damatick's Avatar
If I buy an OEM Honda Accord horn online, any idea how much it would cost for someone to do the swap. Would I have to go to a Honda Dealer or do you think any shop can do this quickly.
Old Sep 11, 2012 | 05:00 PM
other horn? i used my G35C horns (hi & low) in my '12 since im running stabel in my G. my car now sounds like an infiniti.
Old Sep 11, 2012 | 05:48 PM
Wanderer.'s Avatar
Anyone with two working hands and arms should be able to do this fairly quickly. I mean if they can work a screwdriver they're good to go. I don't mean to offend, but this really is as easy as it gets.
Old Sep 11, 2012 | 05:57 PM
it does help to have metal brackets available and spade connectors, crimper, taps, etc if you have it.
luckily for me, the G's horns came with its own brackets. i just had to make the mounting hole a tad larger to mount onto the GE.
here are the infiniti hi and low snails wired up. you dont necessarily need the ground wired up like this, but since the snails had spades, i just used them.
mounted to car:
Old Sep 19, 2012 | 02:30 PM
mrxchris's Avatar
Not sure if this is a dumb question but are these horns the same as the meep noise when you lock the door with the keyless remote?
Old Sep 19, 2012 | 03:19 PM
BlueBoogers's Avatar
Nope. That's a separate horn under the driver's side headlight.
Old Sep 19, 2012 | 04:18 PM
mrxchris's Avatar
Are those replaceable?
Old Sep 19, 2012 | 04:21 PM
Yep. Same type of plug from what I saw. You could do an accord horn there for a deeper lock sound. I don't mind the high-pitched shriek of the stock "lock" note.
Old Sep 21, 2012 | 11:12 PM
Ursenay's Avatar
It literally took me 5 minutes to do the swap with a 2010 Accord horn. It took as long to remove the upper plastic panel as it did to replace the horn.
Hkak45
Dec 1, 2017 03:27 PM
demouser
Aug 30, 2014 10:26 PM
Bobert
Jan 28, 2013 08:41 PM
FitStir
Sep 3, 2012 12:07 AM
PHAMBAM
Sep 30, 2011 04:59 PM
