Lug nuts and OEM steel wheels
Old Oct 1, 2012 | 05:05 PM
Wanderer.'s Avatar
Originally Posted by fiteddy
No donut only in the Canadian ATs. Canadian 5-speeds have them.
That's just weird eh
Old Oct 1, 2012 | 05:13 PM
not really. AT's never get flats in canada.
Old Oct 1, 2012 | 05:20 PM
fiteddy's Avatar
I can attest to that ... I've got flats on my other AT cars, but never on the Fit (yet).
The reason the Fit ATs don't have the donut is to reduce weight to meet some kind of a fuel efficiency norm. I don't believe any of the trim levels in Canada come with TPMS so no advance warning if you're losing tire pressure.
Old Oct 1, 2012 | 05:25 PM
excellent!
so i suppose next time around you guys can buy runflats.
Old Oct 1, 2012 | 05:42 PM
Wanderer.'s Avatar
Old Oct 1, 2012 | 09:17 PM
ohw's Avatar
ohw
IIRC only the 2009 Canadian version came with the "disk" alloys. 2010+LX come with the spokes version. Of course, all LX come with 15" alloys and Sport come with 16" alloys.
Actually, the 2010 LX comes with the exact same "disk" alloys as the 2009. I have a 2010. Can't tell you what comes with 2011 and newer.
Old Jun 26, 2013 | 04:59 PM
KwazyKwaig's Avatar
from my experience, you can use all types of lugs on steelies.
ball, acorn, and washer type. the washer type (for hubcentric wheels) have a taper at the tip which accomodates steel wheel donuts.
just re-torque a few times. i use 88ft/lbs on steelies as they seem to back out easily.
reason being, the taper contact (friction)area is much smaller than most aluminum wheels. your studs can handle more than 90lbs, so it shouldn't break.
Sorry to disagree Kenchan, but what you say is completely wrong and unsafe. There are three basic types of lug nuts. 60º tapered (conical), ball(radius, round, spherical), and washer type.
The tapered are for most steel wheels. The round are for Honda factory alloys and some aftermarket alloys, and the washer type are for most aftermarket alloys.
As has been mentioned in this forum on other threads, tapered lugs will give only "line" contact on alloy wheels, and ball lugs will also give only "line" contact on steel wheels with tapered lug holes. A tapered lug in a Honda alloy will damage the lug seating surface by deforming it. You should make sure you are using the correct lug for the wheel. You risk loosening and even losing a wheel if you use the wrong lugs. Incorrect lugs don't hold their torque properly with road vibrations and cornering forces.
Lug nuts are way cheaper than a hospital visit or a funeral.
stephenmarklay
Dec 30, 2018 04:53 PM
hydrocynus
Jan 3, 2017 01:46 AM
rocketberger
19
Nov 13, 2012 07:30 AM
pandayun
Apr 4, 2012 05:17 PM
Fithonda2008
Sep 18, 2008 07:46 PM
