Car alarm?
Old Nov 8, 2012 | 01:04 AM
Starscream's Avatar
Car alarm?
Can the car alarm be hooked up to the honda key or does it have to have its own clicker.
Old Nov 8, 2012 | 10:23 PM
hogwylde's Avatar
Are you talking the factory alarm or after market?
Old Nov 8, 2012 | 10:29 PM
Starscream's Avatar
well does it already come with a factory alarm?
Old Nov 8, 2012 | 10:47 PM
hogwylde's Avatar
Yes. At least the Sport does. Not sure about the Base.
Old Nov 8, 2012 | 11:09 PM
Tk3's Avatar
Tk3
I have a 2013 Base....it came with the factory alarm as standard equipment.
Old Nov 8, 2012 | 11:12 PM
Starscream's Avatar
isnt that just the keyless entries
Old Nov 9, 2012 | 01:28 AM
Colincarguy's Avatar
Factory Alarm is unsubstantial and only works when a window is broken (and a door handle is pulled from the inside), or the hood is pryed open.
If you want to know your fit is truly safe, get a Viper 5704 installed. Shock sensor (factory doesnt have it) Tilt sensor (factory doesn't have it) glass and proximity sensor (nope) installed it myself and i get real time updates from my car to my key fob about temperature, weather its locked, can remote start it, the list goes on.
Highly recommend it. Factory alarms dont do jack, I can attest to 2 break ins, where the first was successful (smashed passenger window) and a second which failed because they hit the car window, and the shock sensor warned them with 8 chirps. they took off, and i ran out with a bat when i get a notification on the Fob.
Old Nov 9, 2012 | 04:06 AM
Goobers's Avatar
Hum... do you work in sales? Cause it sounds a LOT like a sales pitch. Though, I'll admit, I do have that exact alarm/remote starter.
On little issue I have is that it doesn't disable the factory FOB for my Sport. Why is it an issue? Cause early on, out of habit, I would hit the unlock on my key FOB with the Viper armed... which triggers the Viper to do a quick warning and then go into full alarm blast. I keep thinking I can prevent the blast by pressing buttons on the Viper's FOB, but no success yet.
The only two solutions I can think of (aside from reminding myself to not use the key FOB), is to unprogram the key FOB or to yank the keyless entry module. I don't know what other effects there might be from yanking the module, so I'm very hesitant about doing that. So I think the un-programming the FOB part might be a better solution, though I haven't gotten around to it.
FYI, the GE Fits have always come with the module... it was just the earlier years ('09, '10, etc) didn't come with the key FOB to make use of it on the base trim. But you could buy the key FOB and then program it to the car.
Old Nov 9, 2012 | 09:23 AM
DrewE's Avatar
Couldn't you just take the battery out of the factory key fob? IIRC the ignition immobilizer is a completely separate unit, and doesn't need the battery to operate. If it did, you wouldn't be able to start your car when the key fob battery died to go to the store/dealer to get a replacement.
Old Nov 9, 2012 | 10:22 AM
xxryu139xx's Avatar
I have the same alarm system and the shop wired it up so i can use they key fob or the viper key chain to arm/unarm.
Old Nov 9, 2012 | 04:20 PM
Goobers's Avatar
oh, I hadn't thought about that. Good idea.
A few other alternatives, that I did think about... getting a base key cut. The base trim for 2010 anyway, was smaller since it didn't have the FOB body. I kinda like this idea to remove the overall bulk of my keys, just not feeling like paying for it. The other idea, was to see if I could mate the factory key blade and Viper FOB into one module, similar to the DIY switchblade mod on the forum. Have no idea how to even start to do that though.
really? That's interesting. Might have to research that too.
Old Nov 28, 2012 | 10:57 AM
jeludev's Avatar
Factory Alarm is unsubstantial...
Those factory alarms are really useless, I tottally agree with Colincarguy. But sometimes aftermarket models can be even worse. Some thieves use code grabbers, so it's better to avoid alarms at all.
Old Nov 29, 2012 | 01:26 AM
I dont work in sales, im just a satisfied customer. car alerted me tonight to somebody messing around with the car. They were taking a peek a little to close and the car decided to warn them they were a tad close.
alegr44
Dec 27, 2017 07:01 PM
Silvernitrate
Jun 11, 2016 01:04 AM
FitfulKenny
May 5, 2015 12:11 PM
f1tz1lla
Dec 27, 2012 12:06 AM
its.ryu
Apr 26, 2009 10:14 PM
