2012 Honda Fit Poor Handling
Thanks. My brother who is a honda mechanic in another state, also recommended an alignment check.
THE olem SP7000 dunlops on my old car have 41,000 miles on them now and they still have 60-65% tread life left on them. I drive conservatively.
I dont see why Honda would refuse(or be unable) to do a quality alignment
Ok, I can say for sure now that my 2012 Fit Sport MT handles terribly compared to my old 2010 Sport MT.
The new one is softer on highway expansion joins but has terrible suspension that makes the car very unstable if I rock the wheel.
I test drove my old one last night and could tell without a doubt it was as I remember it - stable like a go cart.
The 2012 also has loud valve train that makes it sound like screws shaken in an empty metal coffee can.
I am disappointed.
Has anyone encountered the same?
I wonder if the 2010 struts would fix the "problem".
How difficult is it to do the valve adjustment without taking it to the dealer?
I am disappointed.
If the valve train is louder I'd check the valve clearances.
For suispension woes, you didn't say if the new Fit you bought new or used. If its used I'd suspect the shocks. Also see if the suspension has been altered at some point with loered springs etc. Last week we had a newly bought Fit here and it drove as rock solid as my 08.
What do you mean by rocking the wheel? If you were actually tugging alternatedly top and bottom of the wheels and you got definite rocking top to bottom there is serious looseness in the suspension that requires immediat
Presumeably, you did check the tiure pressures and condition of the tires, especially for brands and sizes.e attention.
If you want exactly as before go to any online parts store and buy the parts they called out for the year you like (if different than what you have). Majestic, college hills, Honda estore.
If you appreciate your aspects of the new suspension, 205/50 s will make it better.
A little update over a year later.
I had the alignment check at the dealer today and everything seems within spec. Here is the picture of the report.
Does anyone know why it says 2009-2010 Modiefied at the top of the report? The car is 2012 stock with 9K miles.
They've complted a vsa software update/recall. I am not sure yet, but I may have noticed some improvements.
Also, from looking at the reports, does anyone know if the number actual means that it was adjusted compared to the before number?
Stunning revelation of alignment scam. I wonder how many are? I admit I happily walk away with the alignment report provided to me by the tire dealer without questioning its accuracy. Except the only time I've had the fit aligned, their printer was on the fritz. I'll be watching now.
Its not so much a scam as it is the result of poor maintenance and half-way training. Few shops really spend much on either.
You'll do well to measure toe with a stretched string and camber with a level gage angle. And absolutely the OEM only has toe change front only, everything else requires machine shop. The OEM Fit is a world market car that requires as little adjustment as possible so the suspension is crude at best and has a wide range of manufacturing tolerances - greater than the specs.
The biggest detriment to handling of the Fit is the massive understeer decreed by lawyers insisting on going off course head first from lack of traction is make the airbags work best.
What about those before and after specs?
The before and actual (after) numbers are within 1/10 (0.1) of 1 degree (most within 1/100 (0.01) of a degree). The factory tolerances are within 0.5 and 2 degrees.
This slight difference can be attributed to shifting the car's position on the rack (which is normally done to allow springs to settle after making an adjustment). Even total front toe-in, which is adjustable, only has a difference of 0.01 degrees between before and actual with an allowable factory range of 0.56 degrees (-0.28 to +0.28).
just money wasted on your alignment.
you can only change your front toe on this car (if stock) and you went from 0.04 toe out condition on your left while your right was toe out 0.06.
now you have 0.06 toe out on left but your right is now 0.04 toe out. lol
and your trust angle remained 0.06. get a refund.
I am disappointed.
I am disappointed.
The Fit suspension is crude and thus has wider installation conditions such as camber, caster, and toe.
So first check your tire pressures (should be 35 - 40 psig), wheel alignment, ride heights at each corner, and then the tires based on Tire Rack lap times,
if thoses are OK then dtermine just what is your problem with handling: oversteer, understeer, loose steering wheel, tracking, cornering adhesion. Then lets talk again.
It seems rather clear that john22031's car was easily within spec to begin with, so the alignment place didn't alter anything—which is rather what I would have expected them to do (or not do, if you prefer) under those circumstances.
How do you figure it's out of spec? 0.24° ± 0.24° means anything between 0° and 0.48° is okay. (It does appear that the spec was adjusted from 0.24° to 0.30°; but since the readings are within either of these specs, there's no reason to suspect that they changed it to make bad readings look correct. It's also somewhat of a moot point since IIRC rear toe isn't really adjustable on the Fit.)
[/IMG]
