Valves need adjusted at only 41k?
Old Jan 7, 2013 | 11:50 AM
shane's Avatar
Well to continue this topic https://www.fitfreak.net/forums/2nd-...-iat-code.html
Light came back finally and i decided to take the car in for warranty work i was hoping(well i was wrong)
I had the codes read last week and it had a random cylinder misfire along with 2 and 3.
Well i was informed Today that it was due to the valves needing adjusting at 41k and that was the issue. Dealer wants 330$ to do it, but being the do it yourselfer I guess im going to take care of it. I'm used to working on Domestic cars/truck and have done some extensive work there so the knowledge of working on cars and tools is there
Can anyone point me in the direction of a DIY of this or procedure?
Thanks!!!!
Old Jan 7, 2013 | 11:58 AM
shane's Avatar
Or if this even seems correct to the more savvy Honda owners?
Old Jan 7, 2013 | 12:07 PM
phenoyz's Avatar
isnt adjusting those valves part of warranty? its only 41k Miles...
$330.00 !!!! to adjust the valves !!!!
Old Jan 7, 2013 | 12:10 PM
shane's Avatar
That's what i asked. He said since they need "adjusted" its not covered under my Honda care or Factory warranty. Now coming from Domestic motors and not needing this Crap i am tiny bit out of my realm.
To me if valves out of whack are causing a misfire i would HOPE Honda would see that being a COVERED item under the factory and or my Honda care warranty i got with buying the car used with low miles.
Old Jan 7, 2013 | 12:43 PM
TPColgett's Avatar
I got the dealer to adjust my '08 at around 55K under warranty... and I wasn't even throwing codes... I think it depends on your dealer, and how much you press them.
That being said, I know the GD can be done in 2-4 hours in a drive way by an experienced DIY'er with all the tools. If your careful you can even re use the intake mani gasket.
However, I do not know of anyone who has done it on a GE, I would imagine it's a similar process and would be covered in a shop manual or ALLDATA though...
Old Jan 7, 2013 | 12:48 PM
shane's Avatar
Yea i just got off the Phone with Honda over this. They are starting a case on it and going to see what they can do, because honestly i think this should be covered since it is throwing a CEL and WAY before the recommend interval.
Old Jan 7, 2013 | 12:50 PM
TPColgett's Avatar
I was just about to look up your local rep. Especially since you paid $$$$ for the additional warranty and are throwing codes, they ought to handle this...
Old Jan 7, 2013 | 02:17 PM
Wafulz's Avatar
push issue bro they should cover it im taking mines in at 25k to get readjust cuz dam there loud
Old Jan 7, 2013 | 02:38 PM
flash75's Avatar
I wonder how they determined the valves need adjusting? Did they do a compression check? Valves would need to be way off to cause a misfire. Sounds like they may be guessing.
If they really are off that far and you keep driving the car you will need more than an adjustment. The Honda shop manual tells you how. There is another Honda forum that has a step by step valve adjustment for 1st generation cars I assume their would not be a big difference with the 2nd version.
I don't recall the forum name, I lost some computer data, but a search should work.
Clifton
Old Jan 7, 2013 | 09:22 PM
mkane's Avatar
Better loose than tight
Old Jan 7, 2013 | 09:44 PM
shane's Avatar
Waiting to get my call back from Honda tomorrow and see what they say. I'm not 100% sold adjusting the valves will fix the issue.
Old Jan 8, 2013 | 11:16 AM
nikita's Avatar
The only way needing valve adjustment would cause misfire is if they were so tight as to cause compression leakage. If its an exhaust valve it could burn, ironically a "covered" repair.
One difference you have to understand about Hondacare, its really insurance, not a warranty under the law. That usually means that only the specific parts and procedures listed in the policy are covered. A warranty is pretty much the opposite, every thing is covered, unless specifically excluded.
Old Jan 8, 2013 | 11:35 AM
Santiad's Avatar
our fits do require manual valve adjustments at an unspecified interval based on how hard you drive it.
If you ever decide to do it yourself, and you have a GE8, invest on new cowl clips and get a feeler guage.
be careful putting it all back together and make sure you use a torque wrench to the specified setting. Last thing you need it to overtorque a valve head cover screw.
While you have all the crap taken off to get to the valve you could replace the sparks and check the coil plugs....
Old Jan 9, 2013 | 02:20 PM
shane's Avatar
Well Honda called me and told me to call the dealer since i guess they were in talks and now it's being fixed free of charge.
The dealer Service manager was very apologetic over the phone. He is going to get my 78$ back also.
Old Jan 9, 2013 | 02:29 PM
TPColgett's Avatar
Fantastic! Glad to hear it's going to get resolved.
Old Jan 10, 2013 | 07:58 PM
shane's Avatar
Got the car back today they said 2 were pretty loose and 2 were VERY tight.
Guess ill just see if the CEL comes back.
Old Jan 10, 2013 | 08:45 PM
TPColgett's Avatar
Does the car feel different? Better/worse?
Old Jan 10, 2013 | 10:17 PM
shane's Avatar
Feels as slow as ever lol, but really it seems to drive a little smoother.
Old Jan 11, 2013 | 07:08 PM
B Fit's Avatar
Please follow up with more info.
I'd really like to know if this ended your problem with getting codes and a misfire ????
Old Jan 11, 2013 | 07:40 PM
shane's Avatar
No codes still drove the car 80 miles and car does seem to pull smoother and i gained back some MPG.
4d_POWER
63
Jan 9, 2020 08:23 AM
BenQuick
Jul 22, 2017 06:04 PM
wasserball
May 3, 2017 06:02 PM
gmwestberry
Feb 11, 2016 07:44 PM
Stingray
Jan 19, 2016 09:13 AM
