Valve Adjustments
Old Apr 25, 2017 | 11:35 AM
wasserball's Avatar
Valve Adjustments
Page 359 of the owner's manual quotes, "Adjust the valves during services A, B, 1, 2, or 3 if they are noisy." Can someone please define "noisy"? Come on Honda, you can do better than that. Modern cars have self adjusting valves. They do not need to be adjusted like the old cars back in the '60s and '70s. OK, buy a set of feeler gages for those DIY.
Old Apr 25, 2017 | 06:18 PM
woof's Avatar
I think that's simply a misprint. It should really state:
"Pretend to adjust the valves during services A, B, 1, 2, or 3 if the customer is noisy and is making a nuisance of himself on this issue."
Old Apr 25, 2017 | 07:15 PM
Hootie's Avatar
Noisy as in obvious/excessive valve train chatter. Which on the current direct injected L15B1s, will be a bit difficult to single out without a keen ear.
I could see most people doing it in the 100k to 120k mile range along with their spark plugs at the same time (I mean you're RIGHT there and the coil packs are off anyway).
I've typically do mine every 30k to 45k miles... BUT you already know how I drive and that was also prior to boost.
Old Apr 25, 2017 | 09:00 PM
Uncle Gary's Avatar
Probably goes back to Honda's origin as a motorcycle company. Yeah it's a pain. It's not like this is a racing engine that is squeezing every possible HP from 92 cubic inches and needs solid lifters to do it.
Heck, Harley-Davidson has had hydraulic lifters since 1948.
Old Apr 26, 2017 | 03:30 AM
Carbuff2's Avatar
"Adjust valves if noisy"???
Most Hondas I've owned have exhaust valves that TIGHTEN as the miles go on. A tight valve is a silent killer. Ultimately, a tight valve will not close all the way and will burn, causing lack of compression and misfire codes.
Back in the 80s and 90s Honda recommended checking valve-lash every 6 to 12 thousand miles. They got dinged on maintenance costs by USA consumer magazines so they started with the phrase above. Honda also replace many cylinder heads on the B series engines as a result!
Nowadays, Honda uses roller tappet cam followers (rather than the flat tappet or sliding tappets on older engines). So, the adjustments stay in spec longer. But they STILL need to be checked.
I do mine every 50 - 60K miles and they always need some adjustment...you cannot just go 'by ear'.
Old Apr 26, 2017 | 07:14 AM
Uncle Gary's Avatar
Of course you can't go "by ear", especially with the noisy injectors.
Old Apr 26, 2017 | 09:14 AM
oiric2006@gmail.com's Avatar
A video of valve adjustments for the GK5 will benefit a lot of people here in the forum.
Old Apr 28, 2017 | 06:59 AM
SilverEX15's Avatar
Exactly! And be sure to check "Adjusted Valves" on that 100-point Free Inspection sheet they always give you. They barely do the work they charge you for, let alone do a free multi-point inspection. Gimme a break!
Again, it's too bad they don't make a shop manual available to make valve adjustment easier.
Old Apr 28, 2017 | 07:01 AM
SilverEX15's Avatar
I'm glad to hear about the rollers. Where are the adjustment spec listed?
Old Apr 28, 2017 | 07:20 AM
2Rismo2's Avatar
They do. It's just online and you have to pay for it.
When I get some free time, I'll pony up the one day fee and print out all the docs for pertinent info I'm interested in. With an 11 month at home, maybe in 18 years I'll get to it.
Old Apr 28, 2017 | 07:21 AM
SilverEX15's Avatar
Can you post a link?
A search turn up this site.
http://www.hfitinfo.com/hofi-598.html
However, it has lousy "diagrams."
Old Apr 28, 2017 | 07:28 AM
SilverEX15's Avatar
About a shop manual -
Lower Front Bumper Grille Cover Replacement :: Front Grille :: Body Exterior :: Body :: Honda Fit 2007-2017 Repair Manual :: Second generation (2007-2017) - HoFit.org
However, it has lousy "diagrams." The one below shows how to remove the lower grill. Helpful, right?
Old Apr 28, 2017 | 10:14 AM
Carbuff2's Avatar
Look at the emissions sticker, usually on the hood.
If you are lucky, the valve clearance spec is there (along with sparkplug type and gap).
But newer car underhood stickers seem to lack this useful info.
Old Apr 29, 2017 | 08:54 PM
Uncle Gary's Avatar
In the service manual that Honda won't sell you.
Old May 3, 2017 | 09:57 AM
teamcheap's Avatar
I have to check/adjust the valves on my motorcycle every 5000 miles.
I just set aside 2 hours in the afternoon when weather is nice, and do it in my garage.
A six pack and radio set to my favorite station...no distraction.
I think it is actually very therapeutic for me.
It's like I'm taking good care of her.
Maybe its placebo effect...but bike always seem to run smoother better afterwards...and life is good...the rest of the day is usually excellent.
Old May 3, 2017 | 06:02 PM
dwtaylorpdx's Avatar
My KTM 950 requires about 8 hours to do a valve adjust.. Fits are < 1 hour.. I'm ok with that..
amberd03
Aug 20, 2017 11:57 AM
sunnyday
May 27, 2017 09:18 AM
hollyh
Mar 11, 2016 10:43 PM
richardwhite
Sep 4, 2014 09:43 PM
g fit
May 12, 2014 07:06 PM
