Changing Wheels
Old Feb 8, 2013 | 12:38 PM
xTempest's Avatar
Changing Wheels
First of, good day to all! I'm new to the site and 1st time car owner. (Honda Jazz 1.3s M/T)
I'm planning to change 15" OEM Wheels to 17" (205/40/17) and lower it probably 1.5inch or 2inches (which do you prefer?). Is it the safest tire size that is clear from rubbing? Any advice please.
Thanks in advance.
Old Feb 8, 2013 | 06:11 PM
annunC8's Avatar
Thanks in advance.
Try these:
Tire size calculator (You may have to update your Java applet... depending on what OS and version you are using... GREAT calculator!)
Visual Tyre Size Calculator | Kouki Tech
Find Your Tire Size
Hope those help. I think the first link is the best. It shows you the tire difference visually (before and after) and also tells you what different sizes will do to your speedo after the change.
You can also go to Tire Rack, enter your tire size, and choose the other tire sizes option and it will give you other sizes recommended as a replacement for your OEM wheel size. Then use the first link above to see what difference it will make on your speedo.
Old Feb 9, 2013 | 01:42 AM
xTempest's Avatar
Originally Posted by annunC8
Try these:
Find Your Tire Size
Thank you very much!
Mooser1454
Sep 2, 2018 04:29 PM
lastnameD
Jun 28, 2012 04:50 PM
here11
15
Jun 20, 2010 01:40 PM
kayne8570
Jun 16, 2010 12:58 PM
wayneandjudy
Jun 5, 2006 08:47 PM
