What Is The Best Halogen Headlight Bulb?
Old Mar 11, 2013 | 04:10 AM
  #41
raytseng's Avatar
Originally Posted by BraytonAK
It's funny how nearly everyone says their new bulbs are brighter. Well, duh, if old bulbs dim over time then virtually any new bulb will be brighter. It stands to reason that it doesn't matter what you replace them with just that you replace them. The only way to really see if other brands are brighter is to install *one* in a brand new car and test. The rest seems to come down to color preference (to be annoying or not to be annoying) and whether you want them to last a long time or not.
No need to threadcrap.
I gave the stats on my car, that I changed the bulbs at 25k miles.
If the OEM bulbs only "lasts" 25k miles before getting this dim, then it seems like the tradeoff of being "long lasting" isn't cutting it either.
I do not have proof for you that getting new (cheaper) OEM bulbs would not also provide the same effect; only my personal memory that the Philips bulbs made the car lights the brightest that I ever remember(again to my memory). Even getting the car new, I always had the nag that these lights weren't very bright. With the new bulbs, for once I felt that the light output was sufficient. Whether this lasts only 10hours or 100hours or 1000hours remains to be seen. But at least for hours 0-10 so far they are good.
If you are always in a city with streetlights, even the dimmed OEMs are good enough. But for me, regularly I drive this car to tahoe, and the mountain roads are considerably dark at night, and I wasn't happy with the lighting even the first year I had this car (0-7k miles). Enough was enough, and reading this thread prompted me to do some research, switch the bulbs even though they were mechanically OK.
So for the Original question on what halogen bulb is the best standard halogen bulb if you are going to replace them anyway, I would recommend the Philips xtreme vision. (and not spinning into a tangent about modding to HID). So do the moderators and some threads over at CPF.
Do whatever you want, but you should personally try these bulbs so you can report from your own first-hand experience with a specific bulb, rather than just Theorycrafting on it based on hearsay, theories or stuff you read on the internet. Mythbusters always keeps an open mind and tries stuff out, so should you.
Old Mar 11, 2013 | 02:07 PM
  #42
Wanderer.'s Avatar
*shrug* I thought the OEM lights left something to be desired as soon as I drove it off the lot. Whether or not my new bulbs are "brighter" the beam is more concentrated and raising the lights a little bit in combination with that and the whiter light made it MUCH better.
Old Mar 11, 2013 | 02:28 PM
  #43
ThEvil0nE's Avatar
after almost 3 yrs xtreme power gave up the ghost... xtreme vision is coming my way.
Old Mar 11, 2013 | 03:26 PM
  #44
raytseng's Avatar
If one of your XP bulbs is still working, maybe you can take the side/side pictures to satisfy the curious among us.
Old Mar 12, 2013 | 02:15 AM
  #45
ThEvil0nE's Avatar
that would have been a good idea if both bulbs are both new, bulbs dim out over time.
Old Jul 22, 2015 | 01:02 AM
  #46
Shoba Desai's Avatar
Best halogen lamps Brand
I use Bosch halogen lamps for about 5 years and they are working good. My favorite brand is Bosch Halogen Lamps.
Old Jul 22, 2015 | 07:40 PM
  #47
samcl9's Avatar
PIAA's worked great for me before I did a retrofit.
Old Aug 31, 2015 | 12:48 PM
  #48
jps13's Avatar
Originally Posted by n1nj4 m0d3
5000k would give you a slight blue light output, 8000k would give you a purple light output. Stay between 4000k-4500k if you want a white light.
I just put my 8000k bulbs in with 55w ballast... maybe, just maybe a slight tint of blue, but honestly I don't see it, and definitely not purple.. from what I was reading online and youtubing, if I had bought a 35w ballast, then I would get that blueish tint, but with the 55w ballast, like I said, I don't see it.... il upload pics later
Aussie
Jul 17, 2018 12:26 PM
Morair
May 9, 2012 08:26 AM
sdiesel619
Oct 18, 2010 01:21 PM
mxl180
Aug 3, 2010 05:35 PM
Chazzlee
Dec 2, 2009 08:49 PM
