Horn going off indicated the car is LOCKED
Old Mar 5, 2013 | 02:27 AM
lesterlai12's Avatar
My horn doesn't go off when I press the LOCK on the alarm key. Is it just a connection issue, but my horn works when I press it on the steering wheel. Any ideas?
Old Mar 5, 2013 | 02:31 AM
n1nj4 m0d3's Avatar
I've noticed that you have to press the lock button on the remote twice before the horn goes off
Old Mar 5, 2013 | 02:34 AM
It doesn't work when it is pressed twice. Followed all the other threads (hood closed, all doors closed, etc.), and it still doesn't beep. Anyone know problem? Connection problem maybe? if so, any step by step solution?
Old Mar 5, 2013 | 02:40 AM
n1nj4 m0d3's Avatar
Have you tried doing the things mentioned in this thread? http://www.fitfreak.net/forums/2nd-g...en-arming.html
Old Mar 5, 2013 | 02:53 AM
TrungLam's Avatar
Check if its on valet mode
Old Mar 5, 2013 | 11:11 AM
Black3sr's Avatar
Not a cure but FYI. The horn on wheel is not the same one for the locking system. There are two horns.
Old Mar 5, 2013 | 11:29 AM
Mini_Odyssey's Avatar
I dont think that's true, it sounds like one horn found in the front, where is the other horn located? Its not like the BMW and Toyota's with that very faint electronic beeping noise.
Old Mar 5, 2013 | 11:39 AM
Black3sr's Avatar
The Security horn is located on the driver's side behind the front bumper.
Old Mar 5, 2013 | 12:10 PM
Yea and that's the same one that makes noise if i hit the horn button on the steering wheel. Its the one mounted on the core support in front of the condenser yes?
this one>?
Old Mar 5, 2013 | 01:50 PM
Black3sr's Avatar
NO! Look down the top right when facing the car. It is way down behind the bumper.
Old Mar 5, 2013 | 03:16 PM
hatchpat's Avatar
Black3sr is right, the alarm horn is located behind the front bumper in the passenger front area.
Do your parking lights blink when you attempt to press the button twice?
May be fuse related. Or maybe Honda forgot to put your horn for the alarm in.
We have all seen weird things like this before!!
Old Mar 5, 2013 | 03:38 PM
Mempachi's Avatar
does your horn toot when you push it?
Old Mar 5, 2013 | 06:52 PM
specboy's Avatar
+1 for both Black & Pat
There are two horns, one for the security, one for the Steering wheel button. A few people were surprised when they replaced their horn with the accord one to find out that when they pressed the lock button twice, it sounded exactly the same.... (because it's a different horn)
~SB
Old Mar 5, 2013 | 07:26 PM
Vash's Avatar
~SB
man i wish my horn for my keyless lock didn't make a sound.. its embarrassing when that tiny horn goes off.
Old Mar 5, 2013 | 07:35 PM
Mempachi's Avatar
i didnt know about the dual horn..
i actually read in a linked thread to this that there was a valet mode? i was going to try that when i finish work. that might make it totally silent.. *shrug*
Old Mar 5, 2013 | 07:42 PM
specboy's Avatar
Besides replacing or disconnecting... not much you can do. I Play it up and show it off. Some ford locks their doors and the horn honks... I say: "Is that really a horn? How Wimpy is that... Check this out...:" ~meep~ People laugh and I say... Better honda cutting corners there than on the engine, brakes, or tires... It's actually a talking point that has gotten people interested in the car who hadn't really noticed it. go figure!
~SB
Old Mar 6, 2013 | 04:31 AM
Black3sr's Avatar
Well don't push the button twice. Once is enough to lock the doors and if you are close you can hear them lock.
Old Mar 6, 2013 | 11:44 AM
I guess I have to take off the front bumper and see if there is a disconnection or fuse. I read somewhere there was two horns. Thanks for all of your inputs.
Old Mar 6, 2013 | 03:10 PM
Black3sr's Avatar
Why do you want it to beep? A bit of work to remove bumper and it is not likely the horn itself. The fuse is in the fuse box not by the horn. In your manual it will tell you which fuse to check.
stxp64
Oct 9, 2016 12:39 AM
h22dx
Feb 14, 2010 09:41 PM
Kittengolf
Apr 6, 2009 10:20 PM
badself
Sep 14, 2008 06:22 PM
gummyrabbit
Nov 23, 2007 03:30 PM
