Looking for additional blown fuses
Old Mar 23, 2013 | 12:47 AM
Rygrego's Avatar
I was changing the interior dome light bulb in my 2009 Sport & shorted it and the fuse blew. No radio & no interior lighting. I found the blown 10amp fuse and the radio and lights are fine. But the problem now is my alternator light is on and the battery is not being charged. Is there a fuse for the alternator in the panel or is there one in-line under the hood? I did check the three fuses at the positive terminal & all were good. There is no way one little short should take out an alternator.
Please help.
Old Mar 23, 2013 | 02:33 AM
loudbang's Avatar
There are fuses and relays in the underhood box.
Old Mar 23, 2013 | 07:17 AM
flash75's Avatar
"There is no way one little short should take out an alternator"
There are many ways a short can take out an alternator. You should have the alternator checked. It's probably bad.
Clifton
Old Mar 24, 2013 | 12:25 AM
loudbang's Avatar
It's probably the "Main power" fuse in the under the hood fuse box. it's the one that normally is blown when anybody shorts power when "working" on the Fit's electrical system.
It doesn't "Look" like a fuse it's a small box like a relay look on the diagram on the underside of the box lid for it.
And If I remember right (ask me how I shorted mine too) you can't tell from looking at it if it's bad or not you need a test light or multimeter to check it.
Old Mar 24, 2013 | 02:27 AM
Rygrego's Avatar
Thank you, but under the hood are only 3 fuses on the positive terminal of a 2009- 2012 fit battery (no additional plug in fuses or panels) . And all three are good. But thank you.
Old Mar 24, 2013 | 02:32 PM
Rygrego's Avatar
It was the #12 10amp fuse under the under the dash that was blown which controlled the alternator, MAF sensor. All is well now.
Old Mar 24, 2013 | 08:11 PM
flash75's Avatar
Thanks for posting how the problem was solved. Good to hear it wasn't the alternator as I suggested. I should have done some research before attempting to answer your question.
Clifton
Old Mar 24, 2013 | 09:30 PM
Rygrego's Avatar
Clifton
No Problem, I appreciate the input. It was strange that that fuse would blow along with the dome light/radio fuse. The solution to the problem with finding the fuse location was getting out the factory service manual (for better explanations of what each fuse does,) and finding one that listed the alternator. The owners manual use too many acronyms with no explanations. Thanks again for the input. Greg
Old Jul 26, 2023 | 08:48 PM
Doremus2012's Avatar
Fuse blown due to side mirror
Definitely a fuse, but check the harnesses in the door that connect to the mirrors. That’s how I fixed my same problem.
Old Jul 26, 2023 | 09:23 PM
Rygrego's Avatar
I see you're new here. The post is over 10 years old and was remedied 10 years ago as previously posted. And yes it was a fuse the #12, 10 amp fuse under the dash which controlled the alternator and the MAF sensor.
fit_driver_mtl
May 5, 2021 06:20 PM
Gabybeba
Jun 11, 2013 05:07 AM
AWDturbo
Apr 13, 2013 05:58 AM
setter11
Jun 12, 2010 02:38 PM
kyo2529
Oct 2, 2007 01:37 AM
