Wheel stud and bearing replacement
New Stud, Bearing and Hub
I have 75,000 miles on my '10 Sport. About 10 months ago while rotating tires using the supplied lug wrench (BAD IDEA), I mucked up one of the lug nuts (and apparently a stud - more below). Had to have a garage get the lug nut off for me.
Fast forward to mid-May and I'm getting around to removing my snows. That same lug/stud was giving me fits. Threads seemed a bit screwed up, and the lug seemed to have a very slight bend. That lug got tight much earlier than the other 3 did. Well, I was leaving the next day for a 1,500 mile roundtrip vacation, so I threw caution to the wind. About 200 miles into the trip while making a bathroom/fuel stop, at low speed it sounded like a brake shoe rubbing, esp. while coasting. Sound went away while acellerating or once over 25mph or so.
Made it home without any major issues or the wheel falling off, but a few days later it got MUCH worse. Sounded like a jackhammer in the wheelwell and more grinding noises. Not a brake problem after all.
Took it to the dealer after reading about needing things like need a press to replace bearings and or wheel studs.
Need a new bearing, replaced the stud, and a new hub - probably because I put so many miles on after the problem first surfaced. $385 parts/labor. Haven't seen the itemized bill yet so I'm not sure if they replaced the speed sensor or if they were able to remove/re-use the old one.
Part ignorance, part stupidity on my part for going so long without getting it looked at. Just glad I didn't end up on the side of the road in middle of West Virginia on the Sunday of Memorial Day weekend, left to wait until Tuesday to get it looked at.
lannister80
Aug 27, 2016 05:28 PM
Jutboy
Nov 18, 2015 03:39 PM
BMW ALPINA
May 7, 2015 12:36 AM
