2010 Fit valve cover removal?
Old May 11, 2013 | 02:00 PM
YoItsLo's Avatar
So I'm about to change out my spark plugs and I read somewhere that you don't need to remove the valve cover but I don't see how I can fit back there without doin that. Am I wrong? If not, can someone explain how to get this thing off easily? I'm a little new to doing these things on my own so forgive me if this is a stupid question.
Old May 11, 2013 | 02:32 PM
xxryu139xx's Avatar
never done it myself, but here are pics from the service manual
Old May 11, 2013 | 02:34 PM
xxryu139xx's Avatar
Old May 11, 2013 | 02:35 PM
xxryu139xx's Avatar
i hope that's the info u need.
Old May 12, 2013 | 12:52 AM
loudbang's Avatar
xxryu139x has provided the way to do it. But you don't need to remove the "valve cover" however if you remove the "COWL COVER" it's easier to get at them.
It CAN be done with a cold engine without removing anything IF you are used to working with tools without being able to see what you are working on.
Old May 12, 2013 | 12:53 AM
xxryu139xx's Avatar
well either he figured it out how to do it himself, or he went to a mechanic and got it done. all that copy/pasting to jpg and not even an acknowledgement.
Old May 20, 2013 | 09:16 AM
jnesselroad's Avatar
He may not have mentioned anything, but this should be stickied in the DIY section since its asked so much. Major props for all the hosting and pasting jpgs. +rep to you sir
Old May 20, 2013 | 09:28 AM
xxryu139xx's Avatar
thanks jnessel =p
Old May 20, 2013 | 10:08 AM
ThEvil0nE's Avatar
I think I did mine without removing the cowl... other than that, cowl off is the best way of doing it and it's pretty straight forward
ChuckDustin
May 9, 2019 03:34 PM
mecevans
Jun 4, 2015 09:26 AM
Mister Coffee
May 16, 2014 06:42 AM
bluerice
Jul 20, 2008 03:03 PM
AtticusFit
Apr 4, 2008 09:47 PM
