Sounds from lowing window in the heat???
Old May 13, 2013 | 02:22 AM
Piyo2005's Avatar
My 2012 Fit sport front passenger and driver window is making sounds when i lower them. It happens only when is hot (75-85 degree). dont really know how to describe the sound, it sounds like the rail is not smooth, is a low pitch sound, maybe the heat causes something to expand? anyone experiencing this?
it sound something like this, but with a lower pitch.
oh and i do have the windows tinted, but it was fine until recently when the weather got warmer
Old May 13, 2013 | 04:19 AM
loudbang's Avatar
Time to lube your window tracks. This will get a bunch of opinions as everybody has their own strong opinions on the subject.
But anyway I use silicone spray get a can with the skinny tube attached so you can direct the spray right down the track where the window rides with the window up first and it doesn't get all over the window.
Then run the window up and down a few times and see if the noise goes away. If it doesn't you may have to do it with the window down so you can get more spray on the track but the window may need a clean up of the excess.
Don't let the naysayers say this will ruin the rubber in the tracks I have been doing this forever on all my cars and never had a problem.
Old May 13, 2013 | 04:40 AM
Steve244's Avatar
+1 for silicone spray. Make sure it's pure silicone (don't use WD40).
3M makes an automotive brand of silicone. 3M makes an automotive brand of silicone.
Old May 13, 2013 | 04:57 AM
Black3sr's Avatar
It is a '12. Let Honda fix it under wty.
Old May 13, 2013 | 02:23 PM
ThEvil0nE's Avatar
who put a squeaking mouse in there?
^^what Black3sr said
Old May 13, 2013 | 02:24 PM
ThEvil0nE's Avatar
the problem I have on mine are the rattles on the doors when the windows are rolled down or partly rolled down
Old May 13, 2013 | 02:35 PM
Wafulz's Avatar
Dealer asap
Old May 13, 2013 | 03:47 PM
Black3sr's Avatar
We all have those. Some have added some narrow weather stripping for house windows in the channels. I may try that.
runbikerun
Apr 17, 2023 08:57 AM
patm95
Jun 22, 2016 11:36 AM
carid
Jun 9, 2015 06:08 AM
RetroAttack
Oct 15, 2010 10:32 AM
Mezzozero
Jan 29, 2010 08:34 PM
