to bad...
Old May 24, 2013 | 09:24 PM
cbigc69's Avatar
to bad...
to bad we can t do that.
Old May 24, 2013 | 09:25 PM
Do what? 10char.
Old May 24, 2013 | 09:38 PM
cbigc69's Avatar
Originally Posted by mike410b
Do what? 10char.
sorry first picture. I love that engine mod and the sound is amazing.
Old May 24, 2013 | 10:05 PM
K-swap or ITB?
Both are possible, just need much work and money.
Old May 25, 2013 | 03:23 AM
kylerwho's Avatar
spoon fed
Both of those are F20c engines. I actually looked into this quite some time ago and the adapter plate it would require to do the f2k would push the pully into the passenger side strut and make the overall setup too long. Unless you wanted to do some major work on the frame. If you want power just go with k20/k24 swap.
The gd4 in Japan runs a rear axle for "city" 4wd which means you could potentially run a rwd setup but again you are looking at some serious firewall fabrication and frame modification.
It is all possible if your wallet is big enough.
kezay
23
Mar 4, 2022 10:19 PM
k24a2fit
Jan 10, 2015 09:06 PM
crash001
Jul 29, 2011 05:37 AM
ascGD3
Nov 12, 2007 02:56 PM
Mr.Black
Jul 25, 2007 04:16 PM
