16x8 +20 rims on ge8
Old Aug 4, 2013 | 07:42 PM
modxkeith's Avatar
just curious on if it will fit. Has anyone tried it yet?
I'm just afraid that i'll rub, or the wheel poking out too far.
here is my height. i am not planning to lower it anymore.
Old Aug 4, 2013 | 09:51 PM
tjwrnglr's Avatar
Old Aug 4, 2013 | 10:06 PM
lowkeymods's Avatar
Like the other post says...it's going to take coilovers, a heavy roll/pull, - camber, and a super low drop to make it work. Can it work...yes. Is it going to take $2-3k to make it work well...yes.
I'd go with 7.5 max. I even had to run -camber, roll, pull, and cut the fender liner for my current height with 17x7 +40
This is me currently 17x7 +43 and I'll be adding 3-5mm spacers soon. https://www.fitfreak.net/forums/2nd-...rogress-5.html
Good luck, whatever you decide.
Old Aug 4, 2013 | 11:59 PM
1SickVeilsideZ's Avatar
I have 16X8 +15 in the rear and 16X8 +20 up front.
Rear I had to roll and pull and the front I'm running negative camber with SPC bolts.
Once I get my new tires I'm going to slam the car more with alignment.
Old Aug 5, 2013 | 12:54 AM
solbrothers's Avatar
I hope you have stiff springs.
what tire size are you running?
Old Aug 5, 2013 | 01:12 AM
lowkeymods's Avatar
Agreed with solbrothers. If you're running springs, which I suspect you are, go 16x7.
If not, see my previous comments.
Old Aug 5, 2013 | 08:04 AM
modxkeith's Avatar
i'm on tein street basis coilovers. im not going any lower. i like where it sits besides thats the lowest the front will go XD.
Old Aug 5, 2013 | 08:07 AM
modxkeith's Avatar
i am also trying to avoid rolling/pulling.
Old Aug 5, 2013 | 10:31 AM
lowkeymods's Avatar
I'm on the same coils. Because you can't adjust the dampening you don't want low + poke. It won't work. The safest bet is going to be 7" +38-45 offset with a 195 series tire. You can also play around with -camber in the front. I'm sure there's other things that would work, but that's the least likely to require a roll/pull.
Old Aug 5, 2013 | 07:49 PM
pig_pit's Avatar
Im on 17x8 +20. If u dont plan to roll or pull. You're gonna have a bad time.
Old Aug 6, 2013 | 11:14 PM
^can't say it any better than that.
for low car/low offset you gotta have some high spring rates, spring rates that don't come with over the counter coil overs.
gotta get on that koni/gc tip
Old Aug 8, 2013 | 09:07 PM
modxkeith's Avatar
Thanks guys for the input, i know what to do now.
SiRca90
Aug 28, 2020 09:27 PM
kentkanaya
Feb 14, 2013 08:23 AM
DAY54
Jul 7, 2011 10:32 AM
1904-08-fit-sport
Mar 9, 2010 10:03 PM
mykrojas
Oct 19, 2009 11:14 PM
