ruff idle
Old Sep 23, 2013 | 01:39 PM
curchin's Avatar
ruff idle
I have 08 fit sport that idles ruff when cold and dies, mechanic cleaned injectors, no help, said throttle body assembly probably needs replacing,. there 71k milage is this common? bought extended warranty but doesn't cover it, any comments appreciated. thank you
Old Sep 23, 2013 | 04:52 PM
Steve244's Avatar
I'd pay to have it diagnosed by Honda. If it's not an adjustment, I would have thought an extended warranty would cover such things as throttle bodies and coil packs. Who is the warranty with? Just curious. Honda's appears to have it covered (fuel delivery section).
Could be valve adjustment, coil pack (s), etc.
The things don't have idle air control valves (not sure about 08s; it's an earlier generation), I think they're all drive-by-wire. The throttle plate controls idle speed.
Old Sep 24, 2013 | 12:17 PM
curchin's Avatar
Steve, Thank you for your reply, I purchased warranty from Honda when I bought the car new,it states in the small print under items not covered, throttle body assembly. I will take it to the dealer an and have it checked out.
Old Sep 24, 2013 | 01:23 PM
Steve244's Avatar
That sucks. Well if it is the throttle body, ask for a goodwill consideration if it isn't covered by the extended warranty. The current hondacare warranties cover it.
I'd suspect valve adjustment (an adjustment wouldn't be covered. This is medium pricey: $200-$300), coil-packs, and/or bad spark-plugs before something messed up with the throttle body. Older ones (prior to yours I think) had idle air control valves that can get gunked up.
Let us know how it turns out.
Mxzking
Apr 29, 2018 10:25 PM
gmwestberry
Feb 11, 2016 07:44 PM
lakia5524
Aug 17, 2014 12:20 PM
dustinb
15
May 7, 2013 12:54 AM
mastershake
Mar 13, 2009 03:18 AM
