Tpms needs calibration again??!!
Old Nov 10, 2013 | 06:00 PM
Rabee's Avatar
I have winter tires/wheels (stock one)
And summer tires/wheels too.
Each of them has its own tpms sensor.
Yesterday I put the winter setup and now the tpms light is on?!!
It is the stock sensor on stock wheels, don't the calibration setting get stored for different tpms?
Should I go to the dealer torecalibrate for the winter setup then go again when I put my summer setup too?!
Strange and lame
Old Nov 10, 2013 | 06:13 PM
Steve244's Avatar
Strange and lame
It's only possible to register one set at a time. The Honda dealer is going to charge you for the service. I'd expect the tire dealer that sold you the sensors to do it for free.
Or get something like this.
Yeah it's a racket. Honda should have included a feature to learn new TPMS sensors without requiring another device. Looking at the user reviews it seems pretty typical.
Old Nov 10, 2013 | 06:45 PM
Rabee's Avatar
It is frustrating, I tell you why
You are going to end up paying the dealer twice a year for the calibration vs paying the tire shop twice a year to swap the summer and winter tires on the same rim.
The only reason I want the calibration is because I can not disable the traction control when the light is on
Is there a way I can still disable tc with the tpms light on?
Old Nov 10, 2013 | 09:22 PM
patm95's Avatar
I have noticed that there are some TPMS relearn tools on amazon that have gotten some good reviews. Perhaps someone on here could recommend one?
Old Nov 11, 2013 | 02:55 AM
BraytonAK's Avatar
I was just banging my head on the wall today because of the TPMS sensor system. I've been using the ATEQ QuickSet device (linked above) but have found it very flaky. The software used to configure the tool is sketchy. The tool took a lot of time to get working properly a few years ago. It was working fine in the spring and fall each of those years until today. Now, today, the tool seems to be feeding the car corrupted data and no amount of re-uploading data to the tool itself or upgrading the software has helped. I'm stuck with the damn flashing TPMS warning symbol. Endlessly flashing.
As useful as the system was in telling me that I had a slow leak, I had to find which tire myself and I have to use a sketchy aftermarket tool to swap rims every season. P.I.T.A., Honda. P.I.T.A.
Old Nov 11, 2013 | 06:15 AM
jibberjabbs's Avatar
This is a sucky thing Honda has done! Three things I have learned:
1. You can buy a clone HDS HIM that can do everything the dealer can do,for about $150! (Also a trgger device can speed things up)
2. If you need to disable traction control you can disconnect the VSA override button to induce an error that will disable TC and VSA. It is not instant , takes about 2 minutes for me.
3. With a HDS there is a way to trick the tpms system,if you relearn the sensors then remove them from the car before you drive it. It will continue to search for the sensors,but allow you to use the VSA button!
Hope this helps someone, also there are a few treads on here that have more details.
Old Nov 11, 2013 | 07:16 AM
Sprocket's Avatar
I agree that it is a PITA.
And it's not just Honda. A neighbor's new Subaru also needs reprogramming twice a year. I don't know which mfrs are similar and I don't know if any mfrs do it better.
They work pretty hard at keeping us from doing even the simplest tasks.
Old Nov 11, 2013 | 08:25 AM
Rabee's Avatar
How do I disconnect the vsa override button?
Old Nov 20, 2013 | 09:29 AM
Disconnect the connector on the back of the button. It is easy to get to because the panel it is mounted in can be pulled out.
Old Nov 20, 2013 | 09:52 AM
Schoat333's Avatar
This is why I went with continental DWS's. No swapping, and no TPMS headache.
canuck901
Nov 13, 2017 08:07 AM
mandobaron
Oct 10, 2013 12:04 PM
mtgirl
Oct 8, 2013 01:26 PM
mholbrook38
Apr 22, 2009 04:37 PM
panda1314
Dec 29, 2008 02:28 PM
