Electrical issue door locks
Old Nov 22, 2013 | 03:59 PM
Joey Tuller's Avatar
Any ideas what to check when the left turn signal is on and the right rear power door lock unit pulses?
Old Nov 22, 2013 | 06:58 PM
palos's Avatar
I would check for a short in the wiring or a loose ground wire. Both circuits use, in part, power from fuse #16 according to the schematic I found online. However, those circuits indicate it should happen when you use any of your turn signals.
Are you hearing the door lock unit pulse from the door or from the footwell?
Old Nov 22, 2013 | 08:38 PM
sr.sedan's Avatar
If the hearing the acuators going off its most likely is it went bad , I just had my replaced under warranty
wutangben
Jan 19, 2020 05:18 PM
marklj
Aug 27, 2019 03:06 PM
tecra
Jul 22, 2017 08:20 PM
radiolandog
Sep 8, 2014 06:57 PM
VBee
Mar 15, 2014 05:11 PM
