Suddenly out of power...Engine issue...
Old Dec 1, 2013 | 03:21 PM
Sycko's Avatar
Cool Suddenly out of power...Engine issue...
Hi guys,
Just wrote a quick note to introduce myself where it belongs : New to the forum
Here's the engine issue I got yesterday with my GE8 Lx MT5...
Originally Posted by Sycko
Yesterday I was cruising on the highway at 80km/h (workzone) and suddenly I heard a small but really clear "Bang" as if I just hit something on the road (which I didn't) and my little Fit started to make a lot of noise as if it turned out to Diesel on steroids and it came with a major lose of power and lose of speed and no possibilities to keep my speed...
I pulled over and popped up the hood to look if something obvious could be seen and the engine was dancing all over the place with a rumble I never heard from Hondas... Didn't find anything obvious under the hood and got to get it towed to Honda dealership (not the one I got it from, I was pretty far from home and didn't want to pay the towing for a 100km tow)... but if that is known symptoms to a known problem I could use the saved money from fixing it by myself instead of letting it done by the stealership
Let me now if you can think at something I must check to fix it
Take care guys
Old Dec 1, 2013 | 04:16 PM
colnago's Avatar
How many miles on it. What comes to mind is coil pack. Loss of poor and bang ignition going off at the wrong time. No check engine light. Is car under warranty? Had a 1991 Civic hatch when the coil started to act up, 230000 miles while on highway there was a bang loss of power the car would start going again and flames of the unburnt fuel coming out the exhaust pipe. Did that twice in two different occasions coil tested fine replaced with another one had laying around never did it again. Good luck.
Old Dec 1, 2013 | 05:01 PM
Sycko's Avatar
Sorry forgot to mention... 75,000km on it... So engine under warranty but I guess the coil pack are not...
Thanks for your time and for the hint
Old Dec 2, 2013 | 10:59 AM
Sycko's Avatar
Finally it is a spark plug that ripped of the threads and popped off...
Need to remove the head and to helicoil new threads...
I didn't need it... But at least engine's not dead
Old Dec 2, 2013 | 03:48 PM
palos's Avatar
This seems like a recurring problem. (See, https://www.fitfreak.net/forums/1st-...equested.html?) Presumably at 75K they were not the original plugs, did you install the replacement spark plugs, have it done at the dealership, independent mechanic, etc?
Old Dec 2, 2013 | 04:06 PM
Sycko's Avatar
They told me the sparkplugs should be oem since they don't need to be replace before 160 000km...
I didn't replace them but I can't tell if anyone ever replaced them since I have the car since a month only...
Thanks for sharing the recurent story!
Old Dec 8, 2013 | 09:46 PM
Sycko's Avatar
A week later, some news ;-)
They replaced, all under waranty, the complete head!!
So my fit is runninb smooth as hell right now :-)
Thanks for the support!!
Old Dec 8, 2013 | 10:00 PM
Lyon[Nightroad]'s Avatar
Did they note any discoloration on the coil packs. Typically the spark plug loosens its way out a few threads before it rips the last threads out. Usually you should hear a loud ticking/tapping noise which matches rpm's when this happens - usually over the course of weeks. Your coil packs would be discolored dirty brown. You would also see a brown ring around the very base of the ceramic coming out of the base of the top of the plug. This would indicate the plug slowly worked its way out.
Old Dec 8, 2013 | 10:02 PM
palos's Avatar
Good to hear. By chance did they mention that they had previously encountered this? Just curious whether Honda recognizes it to be a potentially recurring problem.
Old Dec 9, 2013 | 05:40 AM
Sycko's Avatar
They told me they never seen this before, but who knows?!
They didn't mention about the coil pack color...
About the loud ticking, there was a ticking sound but mostly audible at idle, I went in Honda to get the winter tires on and they mentionned I should take an appointment to afjust the valves, that it would stop the ticking sound...
Was it a bad diagnostic?
Old Dec 9, 2013 | 09:54 AM
Steve244's Avatar
The tire guy probably isn't a drive-train guy. I'm surprised he said anything about the noise.
It's a good to be aware of; if I hear pronounced ticking I won't delay looking at the plugs.
Wondering if all the Fits throwing plugs are 09s? These were part of a recall to replace lost motion springs in the valve train soon after production. The fix would have required adjusting the valves, the easiest way being to remove the plugs to eliminate compression allowing the pistons to be TDC for proper valve clearance measurement. I'm thinking sloppy torquing when replacing the plugs might be contributing to this.
EhondaGod
Apr 14, 2016 11:30 AM
eyembroke
Aug 16, 2015 02:42 PM
Sycko
Dec 8, 2013 09:45 PM
pandayun
Dec 21, 2011 04:12 PM
mozarwasagenius
Dec 17, 2008 10:21 PM
