oil separator ?
Old Dec 15, 2013 | 09:52 AM
bert96's Avatar
oil separator ?
Hello,
I have search but i did not find anything.....anyone have an oil separator?
something like this...
http://carphotos.cardomain.com/ride_...0051_large.jpg
I took this picture on a nissan forum.
Thanks
Bert
Old Dec 15, 2013 | 10:13 AM
2010FitSport's Avatar
Did you want to ad this for extra crankcase blow by gas collection or are you having a problem with excessive blow gases by and trying to use this to solve it?
Old Dec 15, 2013 | 10:51 AM
palos's Avatar
They seem to be readily available at Summit Racing or even Amazon. I'm also curious why you are looking for one for your Fit.
Old Dec 15, 2013 | 12:19 PM
bert96's Avatar
I did this mod on my mustang in the past,you don't do this mod because of any pfoblems,it just remove any oil vapor that reach the throttle body.
Bert
Old Dec 15, 2013 | 12:58 PM
Steve244's Avatar
oooo I wanna play
completely unrelated battery post with blue thingy. Just two threads down. Scary huh?
Now let's all go and put compressed air water separators on our pcv systems and call it good! I'm sure 13fit will give pointers.
13fit mentions pre-detonation (knocking) as the reason to do this mod. The nature of PCV valves is that they shut when the engine is under load so I'm not sure about this. I don't know how much some hydrocarbon vapor in the mix will add to carbon build up in the cylinders, it would seem miniscule compared to the amount of hydrocarbons in the gasoline that's being burned. I don't think adding a separator would hurt performance of the PCV system any, so long as it doesn't become blocked.
Here's a diagram of the PCV system. It looks like gasses are recirculated to a point pretty far downstream from the throttle body; I don't think it'll gum up the works.
Old Dec 15, 2013 | 03:08 PM
bert96's Avatar
I never heard any problems with this mod,i did this mod also on my Honda element SC in the past without any problems.Lot of guys do this on their cars.May be the Fit does not ''like'' this mod!
Bert
Old Dec 15, 2013 | 04:02 PM
Texas Coyote's Avatar
I down loaded this awhile back when DiamondStarMonsters posted it.. http://www.shophemi.com/images/media..._ccv_bible.pdf
Old Dec 15, 2013 | 06:46 PM
Im not sure anyone said it would cause a problem. I feel like its needed more on a Mustang since Ford has almost always been the king of blow by gasses.
Install it if you want to have that extra insurance against a gummed up PCV system.
Post pics when you get it done too!
Old Dec 15, 2013 | 07:55 PM
Steve244's Avatar
I learned something. Thanks for posting that.
Old Dec 15, 2013 | 09:04 PM
Wanderer.'s Avatar
Oh in to read this later when I'm at a PC. I'm excited lol
Old Dec 15, 2013 | 11:12 PM
13fit's Avatar
I have one. Works great. Check my albums for a vague picture, I havent taken any detailed pics of it yet.
Cost under $30 to make
Simple, effective, and something everyone should have when trying to get as much timing out of the factory ecu as possible. oil spray can cause mild detonation under some conditions.
Anyone who has a bluetooth OBD2 scanner like me and hooks to their phone, can see that honda sees detonation through the knock all too well, and dials back timing severely for several seconds, then very slowly turns it back up.
This is what some people encounter, and may think its a bigger problem. Running 91-93 octane reduces this timeframe of recovery by quite a bit
Old Dec 16, 2013 | 12:29 AM
The blow by is much worse with 10psi boost.. It and heat soak in the summer steals a lot of power and wrecks fuel mileage averages.
Old Dec 16, 2013 | 10:59 PM
SilverBullet's Avatar
Thanks for re-posting. I missed it the first time. Great info.
Mister Coffee
24
Mar 17, 2024 12:54 PM
bill bosco
Mar 17, 2024 01:02 AM
Vince_TB
Apr 25, 2014 11:58 AM
Kwonye
Jan 12, 2011 05:50 PM
buttersandpaper
Mar 25, 2009 10:40 AM
