12-13 Fog Light lens replacement options
Old Jan 9, 2014 | 02:35 PM
painterguy's Avatar
Senior Member
Well before i was able to get Fog Lights protectors i got bit and have a cracked glass.
We all know that Honda only sells the assembly and its a fortune.
In my quest to find a cheaper alternative for a replacement lens and keeping it the factory Stanley lens i have found 2 options.
One is fully confirmed one I will confirm tomorrow.
Parts 33951-TR0-A51 and 33901-TR0-A51 fit 2014 Civic 4dr and are the same lens and are $109.68 per side.
Im working to see if the 2014 2dr is also the same lens but wont have product until tomorrow.
Old Jan 10, 2014 | 11:04 AM
okayhoang's Avatar
Good to know. Though $100 per side is still quite pricey when you get can a whole aftermarket assembly for less than $100 and just swap the lens.
I doubt the 2014 2dr would be any cheaper.
Old Jan 10, 2014 | 11:43 AM
FitStir's Avatar
You can buy just the glass
Fog light replacement glass from rockauto for around $47, or $72 if you want the CAPA certified one.
Originally Posted by hatchlife
if the lens is cracked all you should need is the individual part (#AC2593106) that is just lens with the backing. the whole assembly will have the lens, and housing for the lens that screws right into the bumper
Hey it's alright I had problems finding it the first time as well, this should help for future reference lol
1. Honda
2. 2009 (or selected year)
3. Fit
4. 1.5L L4
5. Body- Exterior
6. Fog/ driving lamp assembly
In step 6 it will have both the lens and the whole assembly. I hope this helps in your future searches
Double check if the 09 is different thank the 12+ (I don't think so), but even if they are different, search using the above method to see if they have it for the 12-13's.
Old Jan 10, 2014 | 11:46 AM
painterguy's Avatar
Senior Member
While i do see your point this post was intended for the peeps that like to stick to factory OEM parts.
And this gives them options of not having to go aftermarket or spending a fortune on the OEM assembly from Honda.
Old Jan 10, 2014 | 11:50 AM
painterguy's Avatar
Senior Member
09-11 Is a different lens
Old Jan 10, 2014 | 11:54 AM
painterguy's Avatar
Senior Member
I have confirmed that 14 Civic coupe lenses are also the same.
33901-TS8-A51 and 33951-TS8-A51 will also work as replacements and list for $93.05.
Old Jan 10, 2014 | 12:48 PM
Waiz's Avatar
Avid FitFreak Poster
Good info in this thread!
Old Jan 10, 2014 | 12:56 PM
xxryu139xx's Avatar
can u take measurements of the internal cavity from the light bulb hole to the bottom of the lens? and the height and width?
if u don't do the hammer technique in replacing the glass, can u see if u can remove the lens by baking it?
Old Jan 10, 2014 | 01:27 PM
painterguy's Avatar
Senior Member
When i get home and get a chance i can mic the measurements you need.
As far as baking the lens not sure but i guess i could pop the broken one in the toaster oven or regular oven and try.
The housing is metal and of course the lens is glass so i can see if it uses that heat sensitive bond material or if its epxoy sealed.
Old Jan 10, 2014 | 01:45 PM
xxryu139xx's Avatar
tyvm =)
would love to see if i can fit a morimoto matchbox projector in it before i try to destroy one of mine. =)
Old Jan 17, 2014 | 10:58 AM
painterguy's Avatar
Senior Member
tyvm =)
Havent forgot about you just have not had the time to swap the lights and try removing the glass from the housing.
56chevydan
Sep 3, 2019 06:32 PM
Aznsupastar
Sep 6, 2018 10:12 PM
running
Aug 7, 2012 03:52 PM
OrangeRevolution
May 15, 2010 12:51 AM
bjyoung
Jun 13, 2007 09:53 AM
