Buzzing noise when letting off throttle - '09 MT
Old Mar 20, 2014 | 09:34 PM
kona.oliver's Avatar
Hi Everyone,
At 100,000 miles I started experiencing a buzzing sound when lifting off the throttle in gear. As the revs start to drop, the engine just doesn't sound as good as it used to, sort of a weaker buzzing sound - could be something loose and vibrating, really not sure. Sounds normal idle and under acceleration - also have not noticed any loss of power. Sound is particularly present as the revs drop below 2500 and continue down to idle before putting in the clutch.
Do YOU know what this is - and if I should fork over some cash to get it fixed??
Old Mar 23, 2014 | 12:09 PM
dfvfit10's Avatar
Originally Posted by kona.oliver
Hi Everyone,
Normally around 100-105k you want to get the a valve adjustment in the honda engines. I had an Acura CL-s 6spd with that same buzzing ticking sound and it was address with a valve adjustment.
Old Mar 24, 2014 | 09:36 AM
Good call dfvfit10, I'll be taking it in thursday or friday.
fitster
Jul 12, 2024 12:46 AM
SuperMacGuy
Sep 26, 2018 10:56 PM
Yeahhhok
May 31, 2018 11:43 PM
Nvillegas
Mar 8, 2013 02:41 AM
ltd
May 25, 2012 08:24 AM
