2013 Fit Wobbles when braking
Old May 10, 2014 | 01:39 AM
Tommyguam92's Avatar
Every time I brake (really only when I come to a stop not just press the brake) my car kind of pulsates like I am pumping the brakes a bit. The actual braking performance hasn't hindered that much but I just got this car a couple of months ago and I don't want to go without treating it because I really like this car and I want this to last a long time.
What could be wrong with it?
Old May 10, 2014 | 02:09 AM
BraytonAK's Avatar
Warped rotors due to overheating the brakes?
Old May 10, 2014 | 02:26 AM
Desmond Lamar MacRae's Avatar
I agree. Make sure you're not "riding" the brakes or they'll overheat and warp. The disc's are doing a lot of work compared to cars with 4 wheel disc brakes.
Old May 10, 2014 | 02:32 AM
ROTTBOY's Avatar
Warped rotors....
Definitely yes!!! My diagnosis too.
Don't have them turned. Cheaper to buy a pair of Centric discs. About $50 for a pair.
Old May 10, 2014 | 04:29 AM
Black3sr's Avatar
Maybe use the warranty and take it to the dealer. While brake parts not usually covered this sounds like a serious problem and they may cover. Either that or maybe the ABS is acting up. It sounds more like what the brakes feel like when the ABS kicks in.
Front brakes overworked because only front disc? Really? This tiny light weight car is easy on brakes. I am at almost 5 years and still on original pads and rotors.
Old May 10, 2014 | 09:15 AM
Red 05's Avatar
Could depend on the driver. My roommate had her pads and front rotors replaced three years ago on her Malibu, and they're warped as hell again.
Old May 10, 2014 | 09:51 AM
Fitguy07's Avatar
Yup, most likely your rotors. You won't notice any performance issues really, just the annoyance of the braking feel. If your steering wheel doesn't have a shimmy, the rotors aren't that bad yet but will get worse over time.
If it is indeed the rotors, I agree with others, start fresh with new rotors and pads, and they should last a loooong time after that.
paul_g
Oct 16, 2016 10:58 PM
ll_TW_Si_ll
Mar 27, 2010 06:55 PM
Chairman Kaga
Sep 14, 2009 02:29 PM
jhoprodie5
Jul 20, 2008 07:15 PM
Reinert79
May 17, 2008 04:46 PM
