Headlights Wont Turn Off
Old May 30, 2014 | 04:26 PM
Dolemite's Avatar
I have a 100% stock, 2009 base model fit with 90000 trouble free miles. Until today. With the ignition off and the key removed my headlights stay on. Additionally, if I turn the fan for heat/cool on it will run without the key in the ignition.
Everything else seems fine. Does anyone have a suggestion as to how I should begin troubleshooting this problem?
Thanks!
Old May 30, 2014 | 04:41 PM
Goobers's Avatar
Are you sure you're turning the key to off? I wonder if the key is worn down as such that you're able to pull it out in the ON/ACC position.
That, or there's a blown relay. Start looking at all the fuses and relay to see if any are blown/burnt out.
But, might be easier to have a mechanic take a look.
Old May 30, 2014 | 05:46 PM
Steve244's Avatar
I'd try disconnecting the battery for a few minutes (reboot). Have your radio code handy.
Old May 30, 2014 | 06:18 PM
Spacecoast's Avatar
Any issues with mice or rodents? In other words, any wire damage that you can see?
GSB__
Feb 24, 2018 06:35 AM
shirtlessthugs
Feb 11, 2015 11:33 AM
chloeishere
Nov 23, 2009 12:41 PM
Funchy
Sep 4, 2008 06:28 PM
CuTeBoi
Jul 10, 2007 07:08 PM
