Any known bugs or issues for 2009 Base AT?
Old Oct 23, 2014 | 08:44 AM
Fit2009BaseAT's Avatar
Question Any known bugs or issues for 2009 Base AT?
Except that valve spring module recall (did that). I've heard something about a/c issues - what is it exactly? Any other known issues to look for?
Thanks.
P.S. So far my parents had no problems at all, except changed rear shock and spring (dealer said it was broken ) and did rotor and pads replacement (also dealer insisted - looks a little fishy to do rotors at 50K, but it's done already). I guess that's not common and is mostly my experience.
Old Oct 24, 2014 | 09:22 PM
hogwylde's Avatar
I have an '09 (Sport) with no issues. The only thing you didn't mention that I BELIEVE was a recall issue was sealing the driver side window control because water could get in and possibly cause a fire.
Please research this as I am not 100% sure.
Old Oct 24, 2014 | 09:39 PM
thanks hogwylde, I'll look into it.
Old Oct 25, 2014 | 03:47 AM
Black3sr's Avatar
I believe that recall was for GDs and not our GEs. I have not had a recall on my 09 for that.. Only bugs I have had are on the front bumper in the summer.
Old Oct 29, 2014 | 09:52 PM
patm95's Avatar
I had the valve spring recall done only on my '09 sport. I have not had any issues whatsoever. I have about 108k on mine and haven't even needed to replace the brake pads, so pads and rotors are somewhat suspicious.
Old Nov 1, 2014 | 02:48 PM
raytseng's Avatar
the fog lights are vulnerable to get damaged from rock hits.
You should get protection film to help protect them. Headlightarmor makes something just for fogs.
There are also reports the condenser also being vulnerable to rocks and to DIY plastic mesh or something stronger to protect that.
Old Nov 1, 2014 | 04:51 PM
Thanks for heads up guys!
Old Nov 4, 2014 | 10:24 AM
seanmcsean's Avatar
I've had A/C issues with mine, as well as electrical issues.
The fuse for the power outlet in the center stack keeps blowing (I go through about one every 6 months, I've changed phones, chargers, etc. It didn't make a difference)
My A/C fan control module grenaded at 70k miles, and thankfully was covered under an extended warranty. Otherwise that would have been a very expensive repair.
Old Nov 4, 2014 | 10:40 AM
seanmcsean's Avatar
Forgot to mention.. My passenger rear shock has developed a puncture twice. Normally I'd chalk that up to the lovely roads in my area, but I've never had an issue with any other vehicles.
Ultrawolf
Dec 8, 2015 04:26 PM
saxoftenest
Mar 20, 2013 01:20 PM
eriko
Hawaii Community
Dec 22, 2011 01:28 PM
Visceral
Sep 23, 2011 12:17 AM
hogwylde
Jun 9, 2011 10:03 PM
