Radio Code — Error #2
Old Apr 26, 2015 | 05:38 PM
Mister Coffee's Avatar
I think I punched in the code for another car. I did this twice and got two error codes. I'm guessing that if I get a third error code, the system will lock me out and I will have to get a dealer to open it. Correct?
Also: Is the radio code a five digit number?
Old Apr 26, 2015 | 07:35 PM
Hootie's Avatar
The radio code is a 5 digit number, you are allowed up to 5 or 6 attempts on some models. After exceeding that count limit, the radio will lock you out for about an hour until you can attempt to unlock it again.
With the radio powered OFF... if you have the radio code sticker with the radio's serial number listed on it, press and HOLD the numbers 1 and 6 along with pressing the power button simultaneously. This way you can double check to make sure that you have the correct code for that radio.
Old Apr 27, 2015 | 12:37 AM
Thanks, Hootie.
I located the correct code and entered it without any problems.
Question:
You state: "With the radio powered OFF... if you have the radio code sticker with the radio's serial number listed on it, press and HOLD the numbers 1 and 6 along with pressing the power button simultaneously. This way you can double check to make sure that you have the correct code for that radio."
If this works, then whats the point of having a "secure" system? Or have I misunderstood you?
Thanks!
Old Feb 7, 2019 | 06:00 PM
VT-Fit's Avatar
Here is how I got my code.
Radio Off
Press 1+6 and the power button at the same time. This will give you the SN of the radio. (write that down.)
Then push 6, then 5, then 2. This is a temporary fix.
go here:
https://www.rensselaerhonda.com/how-...da-radio-code/
Follow the directions. You will also need your Vin number.
Cheers!
crash001
Jun 28, 2024 07:54 AM
john21031
Feb 23, 2020 06:19 PM
simo10
Nov 22, 2015 12:25 PM
mahout
Jun 4, 2011 08:17 AM
Lideusz09
Oct 9, 2009 05:41 PM
