2013 Fit Sport Headlight Plastic Spots
Old Jul 22, 2015 | 04:58 PM
colnago's Avatar
Hey everyone, I was wondering if anyone else has noticed blemishes on there headlight plastic lens. After 3 days of constant heat and sun my drivers headlight plastic casing has developed spots along the edge close to the hood. Pass fine. Car has 19000 miles. Tried wax to remove no good. Looks like heat has damaged the lens. Doesn't look good. Best way to describe it is when you have a black car and the clear coat starts to come off it has that white ridge. Just wanted to see if others have seen this problem will be taking to dealership hopefully for replacement or to get it documented because car is leased.
Old Jul 23, 2015 | 12:22 AM
Mr.Hollow's Avatar
I have actually noticed this too. It looks like clear coat failure, but its plastic so I don't know what caused it.
I guess the best solution is to wet sand them down and polish them. I haven't tackled this myself but I plan to do it before it gets worse.
Old Jul 23, 2015 | 01:19 AM
Codger01's Avatar
Using a good quality plastic polish or polishing compound helps greatly with reducing/eliminating these spots. It's oxidation of the plastic.
Old Jul 23, 2015 | 07:40 AM
colnago's Avatar
I will try some plastic polish and see if it helps. Leased car so not to concerned but don't want dealership charging me for this damage. I know plastic lenses on cars cloud up over time but this looks like if you had two pieces of plastic glued together and the glue in between started to dry and turned white. I religiously wax my car and that spot also gets waxed as well so it doesn't seem like its stained with anything.
Old Jul 24, 2015 | 12:38 AM
Mr.Hollow's Avatar
So i did some research last night and what is happening is the uv coating is peeling off. The coating is applied during manufacturing.
Polishing compounds are good at removing the uv coating, however with no coating the lens will yellow within the year. Its like not having sunscreen on your bare skin.
The only real options are to replace the lenses, buy new headlights all together or get them restored and have a new uv coating applied to them.
Old Jul 24, 2015 | 07:27 AM
colnago's Avatar
Mr. Hollow great info thank you. I will be taking car to dealership for them to look at it. Will post results.
Old Jul 24, 2015 | 03:31 PM
Mr.Hollow's Avatar
Please let me know what they say. A 2013 is to new to be having issues like this.
I hope the dealership covers this under warranty.
Old Jul 29, 2015 | 09:38 PM
Mr.Hollow's Avatar
So I went to the dealership and talked to the service employee. He was a little hesitant but he said they would cover it under the 3 year limited warranty.
Picked up my car with a brand new headlight. I may have had my "scam BS blockers" on max level so maybe I wasn't the most easy going customer but the guy did great customer service and didn't try to pass the blame onto negligence or an "act of mother nature"
So I plan on calling the dealership and giving him a good compliment to the boss tomorrow.
Stacey444
Jul 30, 2019 10:50 PM
Zero2Hero
May 28, 2018 04:55 PM
HONDAMATIC
Apr 14, 2010 11:39 PM
panda1314
Dec 9, 2008 08:45 AM
feddup
Oct 2, 2007 07:11 PM
