rims
Old Aug 24, 2015 | 09:21 PM
GE8FTW's Avatar
rims
will these rims 16x9 fit on my 2010 honda fit or will they rub? And if so what is the widest rim size a fit wheel well can handle?
http://www.ebay.com/itm/ROTA-WHEEL-GRID-V-16X9-4X100-0-FRSB-MIATA-ACURA-CIVIC-INTEGRA-VW-MR2-/291547527734?hash=item43e1963a36&vxp=mtr
Old Aug 25, 2015 | 09:46 AM
DrewE's Avatar
Offset = 0
These will not fit, at least not without very substantial fender surgery, possibly even a fenderectomy.
Old Aug 25, 2015 | 10:16 AM
GE8FTW's Avatar
Originally Posted by DrewE
Offset = 0
Ok thanks might just do 16x7 or 7 1/2
Old Aug 26, 2015 | 06:27 AM
Black3sr's Avatar
7 is plenty but you need to be concerned with offset. Has to be 40 at least.
I am on 16 x 7 with 40 offset lowered on Swifts and I run occasionally.
Old Aug 26, 2015 | 11:47 PM
painterguy's Avatar
Senior Member
17x7 +42 with 5mm spacer in the rear. Rear rolled and pinched front is also rolled and running -2 camber. 195/45/17 tire no rub other than liner on big bumps.
Attached Thumbnails rims-4950ecd7-28d2-48c5-9e7b-090175b6dbe2_zpst4rw6riz.jpg
Old Aug 27, 2015 | 02:46 PM
mine are 16x7 ET40 with 5mm spacer on the rear, running 205/50/16 DWS.
front has -1.5 neg camber using camber bolts, lowered on swifts. absolutely no rubbing at full bump.
Old Aug 28, 2015 | 07:20 AM
Black3sr's Avatar
I should consider adding these bolts as I am beating up my liners pretty good. Where did you get them?
Using original wheel studs on the rear with spacers?
hatchpat
Jul 17, 2013 09:20 AM
Black3sr
Jul 1, 2013 01:32 PM
PEE_ES3
Sep 3, 2011 09:56 PM
fitisbamf
Aug 10, 2011 04:40 AM
HONDAMATIC
Jan 10, 2010 03:23 PM
