ABS Skid Light ON
Old Dec 28, 2015 | 02:32 PM
jdDC's Avatar
ABS Skid Light ON
I have a Fit 2012, and just lately, the ABS Skid Light stayed on. I took it to the dealer who wanted to charge $550 to replace the ABS sensor. I would like to know if anyone has run into this problem and if I would have serious problems not fixing this for right now (very low on finances right now). I am told that the ABS provides the extra umph to braking under wet or snow conditions so the brakes don't lock but does not help much under normal conditions.
Is there a way to just reset this light without fixing the sensor?
My brakes are working well.
Thanks! Jd
Old Dec 28, 2015 | 11:27 PM
xxryu139xx's Avatar
go look behind your wheel and see if the wires are damaged or cut. sometimes u can just solder the wire and fix it that way without replacing the sensor. if the sensor itself is bad ud have to go replace it. check out bernardi parts or collegehillshonda for price or even rockauto
Old Dec 29, 2015 | 07:48 AM
jdDC's Avatar
How to replace?
Thank you for your help! Where can I find the location of the sensor even if I find the part, and I don't know the part number? is there a service/maintenance manual for the Fit 2012 that I can buy somewhere?
Old Dec 30, 2015 | 01:49 PM
dwtaylorpdx's Avatar
ABS sensors usually cost < 100 bucks each on even high end cars,
the sensor usually is near the hub of the wheel an the inside and floats right nest to a
tone ring that looks like a gear sorta..
< 15 minutes to swap once you've done one.
Remove tire, look for the only gadget on the hub with wires, usually a lipstick sized tube with 2 wires coming out running to plug in fender well.
Cheers
Old Dec 30, 2015 | 02:52 PM
jdDC's Avatar
Originally Posted by dwtaylorpdx
abs sensors usually cost < 100 bucks each on even high end cars,
Cheers
thank you!
EggHead
Nov 11, 2016 08:21 PM
GregDavis11009
Oct 28, 2015 08:11 PM
Santiad
Oct 17, 2011 02:55 PM
RandomKoko
Jan 23, 2009 04:51 AM
TAKUSITO
Oct 11, 2006 05:17 PM
