"Check Engine" on lcd display with battery icon
Old Aug 21, 2016 | 12:15 PM
EXT's Avatar
EXT
today I went my local town. while I was driving the lcd displays this message. I didn't stop or did anything, just kept driving. the message went by itself and came back about 5 to 8 times.
when reached home I open the bonnet to examine and find nothing abnormal.
previous owner did mention that it has miner front accident. Is this could be any serious problem later on. the vehicle has about 60k on the clock ...
Honda jazz 2012 GE6 1.3 ivtec
Old Aug 21, 2016 | 12:52 PM
ezone's Avatar
Get the fault codes read.
Old Aug 21, 2016 | 03:53 PM
EXT's Avatar
EXT
I thought someone might went such a sanario before I go ahead for exploring codes etc
Old Aug 21, 2016 | 04:01 PM
ezone's Avatar
The fault code(s) can tell you why the lights are on. It's STEP ONE of a diagnosis.
Codes are not usually a complete diagnosis though. The code scanner is only a tool.
The fault code is probably going to be related to the charging system, but that's the only thing I'm going to guess without more specific information.
Is the current sensor still connected on the battery negative post? Does your car have such sensor?
Old Aug 22, 2016 | 01:01 PM
EXT's Avatar
EXT
no battery negative is connected directly to the chassis. no sensor. this morning i started it and at idle it shows "CHECK SYSTEM" displayed on the lcd with "engine" icon.
will check the connections to the coil. will honda dealer assist regarding fault code?
Old Aug 22, 2016 | 01:55 PM
ezone's Avatar
It still has the battery warning symbol illuminated, yes?
Does the alternator work, is it charging?
I expect they have all necessary equipment if you wish to go there.
Old Aug 23, 2016 | 09:22 AM
EXT's Avatar
EXT
This was very strange while I was checking all the connections, I notice that 1 connector was little lose on the alternator. The lock clip on the connector was broken that might the cause.
I pulled it out and set it back in.
I also disconnect the - terminal and connect it back in.
no warning sign yet......
will monitor and see it goes thanks
FitFreakNC
May 25, 2023 06:32 PM
jgold@desktoppub.com
Jul 14, 2016 11:47 AM
65olds88
Mar 2, 2016 05:11 PM
kchusker6
Nov 29, 2010 03:17 PM
4ow4ow
Dec 6, 2008 12:41 PM
