3 of 4 power windows not working
Old Dec 29, 2016 | 01:23 PM
rocksnap's Avatar
Only the drivers window/switch works. No other window works from any switch. After some web research, I'm going with the window master power module, which is the whole switch assembly in the drivers door.
New from the dealer the part I saw $195, many online Honda sources have it in the $130's.
But I've found a source that uses the OE supplier, with their lifetime warrantee, for $60 shipped!
https://www.switchdoctor.net
Old Dec 29, 2016 | 07:09 PM
ezone's Avatar
If you inadvertently turned off the kiddie lockout on the main switch that would kill the 3 passengers windows.
I've seen a few over the years where that lockout switch or circuit goes bad inside the main switch, not real common IMO but it's happened. If the lockout switch or circuit failed, the 3 window switches in the main would lose their ground.
A voltmeter and a good wiring diagram could lead to proving if this is what happened.
If the power window relay (in the dash fuse box) failed to work for whatever reason, that could also leave 3 windows inoperative. Fuses 15, 16, 17 (dash box) would have no power supplied to them if this were the case.
Just some stuff I'd check before spending money. HTH
Old Dec 14, 2019 | 11:51 AM
man with dog's Avatar
Turns out that was the problem. Never thought to look at that. In all cars I've had the child lockout switch still allowed the driver window controls to work. Only disabled the individual windows.
Old Dec 14, 2019 | 12:40 PM
SiXiam's Avatar
Lucky you! Something really easy you thought was going to be a pain!
Old Jul 26, 2024 | 10:06 AM
Zardiw's Avatar
THANKS!.......That was my problem also.......
Now if someone could solve an intermittent power lock failure problem.....where the powerlock button does nothing.......and sometimes all by itself.........lol
Z
Old Jul 27, 2024 | 01:59 PM
Frenzal's Avatar
Z
Check the wiring at the door hinge. You might have cracked insulation on some wires and they may make contact some times, and not at other moments. Had that problem on my 99 Civic...(door locks would lock/unlock when moving the door or when hitting bumps, and sometimes would not work at all).
awsiany
Oct 27, 2014 09:25 AM
Body2Big
Jun 16, 2014 03:14 PM
x4x5x1x
Jun 29, 2013 07:21 PM
Andrew
Oct 25, 2007 10:47 PM
boogie_down77@yahoo.com
Jun 4, 2005 11:09 PM
