Honda FIT GE8 Headers
Old Jan 26, 2017 | 08:53 AM
De36's Avatar
Talking Honda FIT GE8 Headers
So it's 2017 and I need a header for my 2013 GE8. I had to remove my Weapon R header due to issues, I replaced it with the T1R. I wish I purchased the SuperCircuit header, I found out about it too late. Still might buy it, just to test it out. Most headers by now are discontinued from my search. There are a few still floating around in vendors stock.
This is what is still available that I can find (all are cat-less, all require a CEL Eliminator):
1. SuperCircuit w/o EGR - $285 USD shipped - So beautiful.
2. T1R - $358 USD Shipped - Definitely a close second, bought from A&J Racing.
3. Weapon R w/ mid-pipe - ~$300 USD - I do not recommend this, I had issues with mine and replaced it with a T1R.
Old Jan 26, 2017 | 09:11 AM
De36's Avatar
The SuperCircuit and T1R only remove the front cat. The Weapon R removes both front and rear cats.
You will need a O2 sensor relocator/ CEL Eliminator for all three headers. These can be found on Amazon (everything can be found on Amazon).
The SuperCircuit w/o EGR requires a EGR Block-Off Plate to cover up the EGR port. The EGR has no effect at idle and wide open throttle (WOT), removing it will not increase performance. In fact, you will likely lose MPGs on a daily driver. The purpose of removing the EGR is to clean up the engine bay on track-cars. These are a dime a dozen:
Old Jan 26, 2017 | 12:25 PM
onemiglandicho's Avatar
Good looking out De36!!
Old Feb 12, 2017 | 03:11 PM
FittinglyFittedFit's Avatar
What issues did you run into with your weapon r headers?
Old Feb 13, 2017 | 08:19 AM
De36's Avatar
Click Here
Old Feb 13, 2017 | 09:54 PM
wow, that is pretty bad........and the response from weapon r is also pretty bad......never going to buy from those guys again.
Old Feb 15, 2017 | 01:38 AM
555sexydrive's Avatar
They Supercircuit seem to have a newer version of the GE header that looks as though the primary 02 sensor is already raised and it also has brackets to attach the stock heat shield if one so desires.
Just sent them a message about the cost to include shipping.
Vamprie Nong
Nov 13, 2018 12:53 AM
GE8FTW
Oct 3, 2015 12:04 AM
magnumkdb44
Dec 20, 2014 05:03 PM
dantei136
Mar 4, 2014 10:32 PM
lobomac
May 31, 2011 06:56 PM
