busted back mirror cover
Old Mar 31, 2017 | 01:59 AM
jujujenny2112's Avatar
Does anyone know of any videos on how to remove just the skull cap cover on passenger side mirror.
I have seen videos on how to replace whole mirror, but just need to replace the black cover to it.
Old Mar 31, 2017 | 03:52 AM
Black3sr's Avatar
Old Apr 3, 2017 | 03:09 PM
AirborneRATT's Avatar
I can't see the video posted above from work but I can tell you this:
You have to take the mirror apart to do it. It's really easy though. I had to replace both mirrors on my Dad's fit and it didn't take long to do. I did both in about half the time that I thought it would take to do one so...
P.S. My Dad has a fit, I have a fit and my son has a fit. We love our fit.
Old Apr 6, 2017 | 07:01 AM
Thank you both for response back, I will attempt when/if it ever stops raining here
Old May 8, 2018 | 02:47 PM
John Kuhn's Avatar
My wife's 2015 Fit passenger side mirror has a broken skull cap and also part of the black housing. I have the new parts. Can anyone say if it is necessary to take the inside door panel off to replace these parts? My kit (from Honda) also came with an electrical connector housing, not sure what that's about.
Old May 17, 2018 | 05:50 AM
spike55_bmw's Avatar
This brings up another point, is there a way to get heated outside mirrors?
That would be an excellent & useful upgrade here in the rainy northeast USA.
Old May 18, 2018 | 06:44 AM
Action Jackson's Avatar
Bassguitarist did a writeup and video for his GK. I used it to install my mirror signal lights.
Old Jan 24, 2019 | 06:16 PM
klemmaniac's Avatar
I need to replace the skull on my side mirror as well and cannot get the mirror to detach. I've watched the videos and looked at the links provided and tried to do what was intructed, but the thing won't come off. I have not tried heating it with a heating gun yet (I don't have one currently) and just wanted to check if anyone has any tips on how they finally got the mirror out to replace the skull.
I know I'm looking for a white attachment and need to get a flathead screwdriver in there and turn it to detach the mirror - I have tried this multiple times without success and I don't want to break the mirror. If anyone has any advice I'm all ears - Does it really take a lot of force to get the mirror out? I'm trying to be a little careful so I don't break anything, but maybe it just takes a lot of force and that's how it's done. I'm not 100% sure I'm putting the screwdriver in the right place either, all I know is I'm looking for a white attachment of some sort.
Any help would be greatly appreciated so I don't have to take this to the shop and get gouged.
Thanks.
Old Jan 25, 2019 | 04:55 AM
Black3sr's Avatar
I used this one to replace my covers with winkers
https://www.fitfreak.net/forums/2nd-...s-winkers.html
A couple years later I added the arrows behind the glass using this method
Old Jan 25, 2019 | 01:36 PM
klemmaniac's Avatar
Thanks for the reply - that helps me better understand what things look like on the back of the mirror, though I'm still trying to find a better video for actually removing it from a 2009 Fit. I did find this video for a similar generation Honda Civic, and it looks kind of similar to other vids I've seen with the Fit. There was a good video on removing the mirror from a later generation Fit, but it doesn't look like the parts are the same behind the mirror to me.
Here is the vid for the Civic that I'm hoping will help me:
I'm going to give it another try and try to find where the white plastic meets the black plastic on the mirror and focus on prying that. I didn't think it would require too much force to pop the mirror out, but it's looking like it does. Fingers crossed it doesn't break.
Old Jan 25, 2019 | 02:10 PM
Black3sr's Avatar
You are replacing the white skull cover right? If so then just pry up starting along the bottom to release the clips of the white cover. It is easy. So even if you break it you are replacing it no?
Old Jan 25, 2019 | 02:22 PM
Fiting's Avatar
I have done this operation on several cars but not the Fit.
The plastics and paint are very delicate so are ultra easy to crack and craze. Try to do this on a warm day in the sunlight if possible. The plastics might be a bit more flexible, easier to work & less probable to break; the paint might also be more flexible and less prone to damage.
As weather is so miserable in Cleveland, you might just remove the whole mirror housing and do the cap replacement on warm plastic in a warm room. . .
Also be super careful with the glass mirror. It is incredibly delicate and breaks very easily. It breaks in shards so can cut you pretty seriously. Rubber dish gloves are not good enough.
Old Jan 25, 2019 | 05:37 PM
klemmaniac's Avatar
Yep, finally got it off after focusing on prying the black plastic from the white plastic - the video I posted on Youtube was the clue I needed. I got the skull cap on and when putting the mirror back in and trying to snap it back into place, the mirror broke and cracked. This was trickier than I thought it would be. Snapping the mirror back in place required a significant amount of pressure while holding the mirror on the top in place and, as mentioned, it is very fragile. So I ordered a new glass now and will try to get it in without breaking it and be as careful as I can - very frustrating.
Update:
After ordering the new glass, I encountered the same problem. I don't know how you're supposed to get the mirror clipped back in without breaking it because it requires a lot of pressure to get the bottom clips to connect. I got one clip connected on the bottom and tried to press down to get the other side connected and it wouldn't clip. I didn't want to break the mirror again, so I'm just leaving it on with the one connected clip - the top clips are holding it in place as well so I think it's fine and stable enough. Warning to others trying this - be careful clipping the mirror back into place - don't ask me how to do it without breaking it.
If anyone has any tips on how to get the mirror back in place and reduce the risk of breaking it, I'd be all ears.
HomelessScientist
Nov 27, 2012 06:05 AM
Chazzlee
Mar 27, 2011 10:40 AM
timfield
Mar 24, 2011 10:06 PM
estlin
Jun 23, 2010 12:07 PM
drock46
Feb 10, 2010 03:40 PM
